Author Topic: idle consumption??  (Read 2108 times)
mathewst
  • Split, Croatia
    • v40
idle consumption??
« on: 07 December 2009, 22:39:11 »
Well can anyone with 2.2 petrol post their idle consumption while the engine is at running temp.
I'm a bit corious.
Have some small problems with the mig, seems the car is a bit slow so I was thinking of clogged injectors.
Reading on the net it looks like clogged injectors raise consumption a little so just want to check
Also has anyone had their cleaned?
I heard all say injectors can be cleaned properly only by ultrasonic devices so was thinking of giving it a go
Re: idle consumption??
« Reply #1 on: 07 December 2009, 23:21:55 »
0.3 gal per hour i think
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #2 on: 07 December 2009, 23:26:09 »
Same here .... 0.3 at idle  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 08 December 2009, 06:43:29 »
0.3 is correct.
Have you cleaned out the breathers and throttle body?
I like red cars
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 08 December 2009, 08:22:24 »
Yep breathers and throttle body are clean.
I guess two possible problem, either clogged injectors (fuel here is sh...) or cat is on its way out.
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 08 December 2009, 08:23:22 »
Hmm but 0.3 seems a bit high to me also cause mine on idle is 1.0 to 1.1 litre/hour
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #6 on: 08 December 2009, 08:48:53 »
Try some Red-X or similar with the next few tanks of petrol.
1.0 is far too high.
I like red cars
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 08 December 2009, 08:52:21 »
1.0 in litres not galons. That is around 0.25 galons I think
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 08 December 2009, 09:16:08 »
Sorry, didn't read it properly, that sounds fine.
I like red cars
mathewst
  • Split, Croatia
    • v40
« Reply #9 on: 08 December 2009, 10:13:03 »
Read somewhere that the car can be slower after having the head of and cambelt changed.
Mine was done couple of thousand miles ago.
They say that the phase could be setup wrong
Can anybody say is this correct?
« Reply #10 on: 08 December 2009, 14:14:31 »
Mine idles at 0.2g/hr rising occassionally to 0.3, but drops again to 0.2. It has never been lower than 0.2 or higher than 0.4 regardless of what ancilliaries I have on.HTH :y
« Reply #11 on: 08 December 2009, 14:24:37 »
There's no reason for any engine work to make the car slower unless it has been done incorrectly.
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #12 on: 08 December 2009, 18:11:34 »
With the aircon off it is 2.0, lights and aircon on sometimes 3.0 on my 2.2 estate.
Pippin
  • Birmingham
    • Vauxhall Signum 1.9CDTi
« Reply #13 on: 08 December 2009, 19:39:04 »
mine usually goes between 0.3 and 0.4 at idle with aircon off and 0.4 to occasionally 0.5 with aircon off. It used to run at 0.3 all the time when i first had it but think it changed slightly ofter LPG'ing it... :)
RoSPA Gold Advanced Driver
Trade Card Holder
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #14 on: 09 December 2009, 09:10:38 »
0.2 - 0.3 on idle for me  :y
v6 thats warm  :y
