Author Topic: rear passenger footwell  (Read 4915 times)
« on: 15 December 2009, 10:24:21 »
Is soaking again! Front passenger carpet is bone dry, scuttle drain is also totally clear. Rear door seal looks fine I cannot see any trace of water coming in from that. I really have no idea where this water is coming in from. ::)
Re: rear passenger footwell
« Reply #1 on: 15 December 2009, 10:25:42 »
Been carrying the dogs?  ;D ;D ;D
« Reply #2 on: 15 December 2009, 10:29:59 »
not for a while  ;D
Its a very damp smell, not very doggy! Its i worst in the bottom right corner of the footwell, towards the front under the front seat its still dry.
I can only think someone years ago before i had it spilt a huge amount of water or something down there which soaked into the insulating foam.
The carpet around the sill appears dry  :-/
« Reply #3 on: 15 December 2009, 10:31:09 »
should add the car does not steam up or anything when left or when driving, so i don't notice it unless i look under the rear matt, its seriously wet underneath that  :(
Ken L
  • Sheffield, South Yorkshire
« Reply #4 on: 15 December 2009, 10:36:02 »
Is perhaps getting in from underneath with all the wet weather? maybe through a drain hole, or a grommet gone missing?....just a thought, had this in the past.
« Reply #5 on: 15 December 2009, 10:39:36 »
thats the only place it can be getting in, i'll jack the back up tonight and take a look  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 15 December 2009, 11:01:57 »
There is certainly a grommet under the back footwell might be that This probably wont help but I recently cleaned out my scuttle air intack well behind the pollen filter with a hose and got water in the fan housing which found its way to the back footwell not much in the front footwell but a lot in the back To get rid of the smell I tried various sprays after drying out with a hair dryer  but had to replace the underfelt to obtain success.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #7 on: 15 December 2009, 11:10:14 »
dose yours have them plastic clip in the carpet holds down the carpet, and the plastic pin can fall out and leave a hole to the out side.
« Reply #8 on: 15 December 2009, 11:11:18 »
How did you do that, spray with the hose behind the pollen filter?
I have not cleaned the scuttle for ages, although i inspect it quite often so know its clear.  Infact i don't think i cleaned it since i last Vaxed it and got all the water out.
I'll check for this grommit tonight, if is is leaking, will there be any problems sealing it with some goo of some kind? Does this gromit need to 'breath'?
« Reply #9 on: 15 December 2009, 11:12:46 »
Really?  :o - All that stands between the outside 100mph 70 mph motorway crap going underneath the car is stopped by that? I would have thought that would be attached to the sound proof stuff, not into the metal work?  :-/
It does have the clips in the floor, but the mats i have in the back (geniune GM) don't have the holes so never used them.
Really need to get unneath to investigate, which i might do at lunch time today  :y
« Last Edit: 15 December 2009, 11:14:26 by tunnie »
« Reply #10 on: 15 December 2009, 11:16:01 »
are the ac drains clear? Do you see 2 drips/ puddles under the car with ac on? Just wonder if its baking up.
Have you checked the door membrane is still sealed?
« Reply #11 on: 15 December 2009, 11:19:29 »
I have seen puddles under the car, usually after an oil change as i leave the car running in the garage for a bit. But i will double check again.
Door seals look fine, there is dirt in the seals which has not moved, and does not point to any water ingress. Around the plastic sills too there is no apparent water intake, the carpet towards the door is dry, its just the bottom corner on the right (closest to the drive shaft tunnel)
rustym95
« Reply #12 on: 15 December 2009, 11:27:12 »
the one that fell out on mine was straight through got new one for 10p inch and half round top with like slim figerd woman that clips in to the plastic bit in the carpet, need some one to hold down the carpet so can be pushed in, the reseal the out side.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #13 on: 15 December 2009, 12:05:53 »
The grommet in the back footwell on mine was ok but I still covered it in underseal to be sure
« Reply #14 on: 15 December 2009, 14:19:47 »
sorry about the crap photo, took it on my phone, but should this hole be dripping water? Rest of the car is dry (as the drive to work was)
This was taken towards the middle of the car, rear passenger footwell....
