Author Topic: 2.5 TD ORANGE LIGHT ON DASH  (Read 1368 times)
Eric DUBLIN
  • DUBLIN
« on: 16 December 2009, 00:18:11 »
HI THR, MY 2.5TD ENGINE MNGMNT LIGHT COMES ON WHEN CHANGING FROM 1ST TO 2ND IF REV BAND IS AT 2000 OR LOWER SAME THING SOMETIMES WHEN SHIFTING OUT OF 3RD! THRS ALSO A MOMENTARY LOSS OF POWER WHEN LIGHT ILUMINATES!  PLEASE ADVISE PROBS&SOLUTIONS
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: 2.5 TD ORANGE LIGHT ON DASH
« Reply #1 on: 16 December 2009, 01:14:22 »
you will need to read the codes stored as could be anything auto ecu to engine ecu.
Omegatoy
  • UK
« Reply #2 on: 16 December 2009, 08:29:38 »
OH OH OLD FRIEND THIS ONE!!
search on here for diesel magic trick and cary it out a couple of times, it should help it but as said may need a couple r three even goes till it sorts it, bet code will be fuel sensor out of range!!
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #3 on: 16 December 2009, 09:04:06 »
Orange light?
Probably a Christmas decoration! ;)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 16 December 2009, 10:16:08 »
Aye - the dreaded code 64!
« Reply #5 on: 16 December 2009, 11:33:10 »
Listen to the sensor, its saying you should have bought a petrol  ;D
« Reply #6 on: 16 December 2009, 11:47:23 »
Listen to two short Tunnie. Even the 2.5 diesel has the right amount of cylinders ;D ;D
« Reply #7 on: 16 December 2009, 18:25:13 »
some tractors can be paperclipped. symptoms sound like 64 though...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #8 on: 16 December 2009, 19:43:22 »
and looking at your fuel spending figures will tell you otherwise.  ;)
« Reply #9 on: 16 December 2009, 21:41:33 »
It maybe 2 pot down, but at least its batting for the right side  ;D
« Reply #10 on: 16 December 2009, 21:41:49 »
LPG soon  ;D
osealy
  • dublin
« Reply #11 on: 16 December 2009, 21:55:40 »
I'd say they are all correct , except for Tunnie.
Apparently the sensor can be changed in situ.
If it starts OK when hot just ignore it.
