Author Topic: track rod ends  (Read 1706 times)
seosamh
  • belfast
track rod ends
« on: 21 December 2009, 20:49:09 »
anyone know the part no. for above to suit 02 2.2 dti.thnx
Re: track rod ends
« Reply #1 on: 21 December 2009, 21:26:43 »
I would buy from a factors for 1/2 the price  :y
but
Omega        Part Number        Retail Price        Normal Trade        Trade Club
Track rod ends
Outer joint RH (long) to '99                                     90510654       £53.00       £45.09       £32.43
Outer joint RH (long) from '00                                    9193099       £39.75       £33.81       £23.27
Outer joint LH (long) to '99                                     90510653       £53.00       £45.08       £32.44
Outer joint LH (long) from '00                                    9193098       £39.75       £33.81       £23.27
Outer joint RH (short)                                      90510652       £37.45       £31.87       £23.25
Outer joint LH (short)                                      90510651       £44.45       £37.82       £28.37
Centre tie rod assembly - exc. lowered sports chassis from '00                              90510648       £162.00       £138.52       £103.67
Outer tie rod assembly, RH to '99                                    90510649       £109.00       £92.68       £70.39
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: track rod ends
« Reply #2 on: 21 December 2009, 23:17:28 »
have them at vauxhall center half price £17. only till 27th december as vat gose up on 1st of jan.
kcl
  • Finland
    • Volvo V60 D4 -14
Re: track rod ends
« Reply #3 on: 22 December 2009, 06:54:48 »
What is the difference between pre-99 and 00- onwards? Pattern catalogues only list one item for all models?
« Last Edit: 22 December 2009, 06:55:10 by kcl »
seosamh
  • belfast
Re: track rod ends
« Reply #4 on: 22 December 2009, 22:01:59 »
but
Track rod ends
1 x 606725120 @ 14.23 GBP
Track Rod End (Right Hand)
for: Vauxhall Omega 2.2 2002
1 x 606725130 @ 14.23 GBP
Track Rod End (Left  Hand)
this is the part numbers i got from eurocarparts...am i buying the wrong part?
rustym95
Re: track rod ends
« Reply #5 on: 22 December 2009, 23:08:40 »
there is iner and outer, outers are dif shap and size iner look the same but are not, forthat price sounds like iner's, AtoZ motorspares are cheap had a good rep so told there iners are £16.85 and that is with P&P, info is , info@a2zmotorspares.co.uk open 7days a week or  call 01782817417 dont know if that helps and they send out for next day. DHL. :y
