Author Topic: Paper clip test for gearbox ECU  (Read 1113 times)
trinity0_10
  • Norfolk
« on: 29 December 2009, 08:48:31 »
What pin numbers on the 16 plug Omega do you short to get the gearbox ECU to flash faults?
Mike
Omega Elite 1999 2.5 saloon LPG
Vectra SRi 1998 2.0 Estate LPG
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Paper clip test for gearbox ECU
« Reply #1 on: 29 December 2009, 08:52:00 »
think you will need tec 2 to read it.
« Reply #2 on: 29 December 2009, 08:52:16 »
To my knowledge the gearbox doesnt support code flashing.
the only code flash ive heard of besides engine, was ABS on cavaliers.
trinity0_10
  • Norfolk
« Reply #3 on: 29 December 2009, 09:20:41 »
I found a right up on gearbox, alarm & ABS code flashing, it told you which pins for the Astra & Vectra 10 pin but not the 16 pin although it was mentioned as possible?
Mike
rustym95
« Reply #4 on: 29 December 2009, 09:26:08 »
Vectra B is only model same as omega, new vectras have dif pin allocation.
« Reply #5 on: 29 December 2009, 09:29:27 »
As others have said, only the All other onboard systems on Omega require a decent code reader.
