Author Topic: Headlamp adjusters (levers)  (Read 1226 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
« on: 03 January 2010, 11:29:22 »
Hello everyone,the levers inside the lamp unit,,does anybody know the correct position for them, up or down.
I,m sure that I read a question about this last week so I checked mine,1 up+1 down,no wonder my lights are useless.
                    Thanks for any info
                         Regards Alfie.
Welung666
Re: Headlamp adjusters (levers)
« Reply #1 on: 03 January 2010, 11:34:49 »
If you mean the metal arms then they should both be up, and if they are projector headlights (non xenon) then pick up a pair of nightbreakers off eGay :y
« Last Edit: 03 January 2010, 11:35:43 by Welung666 »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #2 on: 03 January 2010, 11:53:15 »
..............of course the lever position assumes that the adjusters inside the headlamps have not broken -in which case buy new headlamps
« Reply #3 on: 03 January 2010, 12:40:44 »
No they shouldn't! OP is correct, one up & t'other down!  :y
click here Page 121  :y
« Last Edit: 03 January 2010, 12:42:07 by Andy_B »
alfie
  • Gwent
« Reply #4 on: 03 January 2010, 12:41:24 »
Hi,They are new lamps fitted with nightbreakers but not o/e.
whoever designed these lamps must have been a moron.
                 cheers for the info,
                      Alfie
alfie
  • Gwent
« Reply #5 on: 03 January 2010, 12:45:12 »
Andyb,Thanks for your post,can you tell me which side is ,and which is down.
                 Cheers
                          Alfie.
« Reply #6 on: 03 January 2010, 12:46:56 »
                 Cheers
                          Alfie.
Left light .... lever up
Right light ..... lever down  :y
And as it suggests, you should see an upsweep of the beam pattern if you park ifront of a garge door/wall ie
 \____   \____ if you have the levers wrong for RHD ie set up for continental Europe, you should see ____  ____  :y
« Last Edit: 03 January 2010, 12:48:59 by Andy_B »
