Author Topic: Removing brake switch  (Read 1145 times)
« on: 04 January 2010, 13:02:41 »
Right, I`ve slid the outer sleeve away from the switch body. Where are the tangs to push to remove the thing. 12 o/c & 6 o/c
from the driver`s seat or 3 o/c & 9 o/c :-? >:(
And what do you use to push `em both at the same time :question
« Last Edit: 04 January 2010, 13:05:09 by RobG »
hotel21
  • The Kingdom of Fife
Re: Removing brake switch
« Reply #1 on: 04 January 2010, 13:12:23 »
I see you are also looking at the cruise fitting guide.   :y
There are tangs on either side, press both together to remove.  Cant remember what position of the clock they will be though....
« Reply #2 on: 04 January 2010, 13:14:27 »
I used the temper method, of brute force.
you cannot reuse the switch though  ;D
« Reply #3 on: 04 January 2010, 13:14:42 »
Blonde moment. Do I press at the "body" side of the switch or the plunger side?
hotel21
« Reply #4 on: 04 January 2010, 13:15:03 »
If you do it as per the guide, you can reuse!   ;D
hotel21
« Reply #5 on: 04 January 2010, 13:16:33 »
Make sure the red plastic part is out, as opposed to in, I think, then press both parts of the side at the same time.  I think I pressed one and then angled the switch a little bit to keept it depressed whilst I did the other side, if that makes sense?
« Reply #6 on: 04 January 2010, 13:18:20 »
I`ll give it a go now B. You must have bloody small hands or strong fingers ;D
« Reply #7 on: 04 January 2010, 13:20:07 »
Im far too big to fit under there in any reasonable position, hence attempting the push one, and pull slightly to then try and do the other, but failed miserable and pulled the bugger out.
new ones gone in much more easily though  :y
Matchless
  • Nottingham
    • A white van
« Reply #8 on: 04 January 2010, 13:28:38 »
I think there are some photos in the auto to manual conversion guide which might help
« Reply #9 on: 04 January 2010, 13:36:09 »
Cheers M. Go and have another try now. Been pushing the wrong sides of the switch :-[
« Reply #10 on: 04 January 2010, 14:15:13 »
Switch out and in one piece :y :y
« Reply #11 on: 04 January 2010, 14:19:04 »
good work fella  :y
