Author Topic: Battery clamp bolt  (Read 3725 times)
acura
  • Lancashire
Battery clamp bolt
« on: 09 January 2010, 14:36:40 »
Hi, quick question,
Does anyone know the size and length of the bolt that holds the battery securely to its tray. I changed my battery the other day and sheared the bolt undoing it. I guess I could just drill out and use a nut and bolt but would rather use the prescribed method. Cheers.
From Consul 375 to Omega, 30 cars and counting.....
Neil_MV6
  • Sutton Coldfield-West Midlands
Re: Battery clamp bolt
« Reply #1 on: 09 January 2010, 14:45:36 »
Is it worth worrying about? There's precious little room for the battery to move around anyway is there?
Someone is going to come on and tell us how vital is now, you watch.......  ;D
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #2 on: 09 January 2010, 15:06:51 »
Yes, you are dead right in saying that someone will come on.........
Fact is that is a requirement of the MOT to have the battery secured!
Quite apart from that the bolt is a standard 8mm setscrew, that is it is threaded from the head to the end. I reckon it is about 40-45mm long and goes through a metal bracket that locates on the side mouldings of the battery at its base.
The easiest way is to drill the bolt centre that is still visible as big as you dare without destroying any threads and then give it a good old soak in wd for a few hours. After that just drive a file tang or whatever elseyou can  that is suitable into the hole and twist it clockwise until the snapped off bit goes completely through. It will be easier than trying to turn it out as though loosening it! Quick clean up of the threads with a tap and jobs done. Done it before so I know it works! Put a dose of grease on the new bolt to prevent this re-occurring.
Hope that helps, just get it secured to be safer than sorry later.
GudLuk
« Last Edit: 09 January 2010, 15:13:48 by its.ray »
acura
  • Lancashire
« Reply #3 on: 09 January 2010, 15:15:33 »
 ;D Yep cheers.
I knew it was an MoT requirement and it also secures a section of wiring harness. I may just pick up an M8 nut and bolt and drill through.
Ta for the replies chaps.  ;)
« Reply #4 on: 09 January 2010, 16:47:39 »
I can sort you out with a nice shiney stainless nut & bolt if your bit of Lancs is anywhere near me  :y :y :y
Neil_MV6
« Reply #5 on: 09 January 2010, 17:17:52 »
That's me told then.   :-X
;D ;D ;D
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #6 on: 09 January 2010, 17:22:16 »
also if you are stop checked by police they can impound you car as it is a fire risk.
13mm bolt 2inch long standard thread.
« Last Edit: 09 January 2010, 17:23:40 by Russell_Hill »
acura
  • Lancashire
« Reply #7 on: 09 January 2010, 17:48:17 »
Most kind Andy but I live in Skelmersdale so a fair way from Bury. Plus the fact that I've been unable to use my car since Monday due to the weather makes a trip a bit unfeasible. Thanks anyway.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #8 on: 09 January 2010, 19:25:38 »
Eh?
Do you mean a 13mm spanner or socket will fit the bolt head?
If so the bolt will be an 8mm threaded bolt.
The length is around 25mm long.
If the bolt has broken and you can't remove it with grips etc.... try and make a flat spot on the top of the broken bolt, either file or grinder. Used a small drill 1/8 (or 3mm) of an inch as a pilot drill. Then go slightly bigger each time. When you have drilled with about a 6.8mm drill bit, use an 8mm tap.
Job done.
Daz:y
« Last Edit: 09 January 2010, 19:30:55 by Loo-knee »
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #9 on: 09 January 2010, 19:29:22 »
Actually, its an M8 hex head bolt, 25mm (1") long..
Have me battery on charge this minute, and clamp is stood right next to me!!
Must admit, I put a bit of copperslip on the bolt before I put them back, (also do the wheel centre locking bolt) as it helps when you come to remove it at a later date.
« Last Edit: 09 January 2010, 19:29:50 by Dodger »
I always knew I'd inherit an estate, but I never thought this would be it!
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #10 on: 09 January 2010, 19:31:43 »
Always a good move :y
« Reply #11 on: 09 January 2010, 19:34:38 »
I tend to use vaseline all over battery bolts and terminals.  Obviously, Loo-knee, I know you ran out of Vaseline, using it on Elite Pete....
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #12 on: 09 January 2010, 19:36:26 »
Funny as I was going to say the same for You and Tunnie  ;D ;D ;D ;D
« Reply #13 on: 09 January 2010, 19:38:02 »
Tunnie only has eyes for JamesV6CDX, according to the photos I have after the Brackley cambelt meet  :-X
  • Auckland
    • Mazda MPV
« Reply #14 on: 09 January 2010, 19:39:04 »
M8 thread (with 13mm AF hex head)
