Author Topic: Since all the Snow - Strange Smell  (Read 2900 times)
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
« on: 15 January 2010, 14:17:04 »
I have started noticed a burning sort of smell after a short or long drive since all the snow etc. To me it smells like brakes or clutch, like its just been driven like a loon.
Now its an auto so i'm assuming the clutch isnt like a manual one but I don't know, I was worried that I had maybe done some damage as I have been getting stuck in the snow quite allot and the TC and 3rd Gear snow mode has been getting quite a battering. Can this cause problems? Or is it more likely to be the brakes for some reason? They feel fine but could they be binding due to the temperatures?
Cheers
bigdods
  • Brackley
Re: Since all the Snow - Strange Smell
« Reply #1 on: 15 January 2010, 14:20:02 »
I was greeted by a burning smell just before the aux belt tensioner expired. Probably the smell of the belt slipping, only takes a sec to check the condition of the aux belt and eliminate it.
richardirv
« Reply #2 on: 15 January 2010, 14:30:22 »
Well its practically a new belt thats on, I know it doesn't rule it out completely but I should of mentioned earlier that when I opened the bonnet there wasn't a smell there really, much worse coming from either under the car or front wheel arch which is why I assumed brakes.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #3 on: 15 January 2010, 14:39:17 »
I had the same problem....seems to have filtered away now.
Confinced myself it was something to do with the TC, the slipping of tyres and mis-firing as the computer dropped a couple of cyliners in order to help the car get grip.
richardirv
« Reply #4 on: 15 January 2010, 14:43:56 »
Glad to see its not just me then, maybe there isn't anything wrong. I hope your right.  :y
Its just that it was the same on my work today and apart from getting out of my street the roads are ok, so couldn't explain why it still smelt.  :-/
« Last Edit: 15 January 2010, 14:44:48 by richardirv »
cam2502
  • dumfries,scotland
    • 08 BMW 520d & 03 Saab 95
« Reply #5 on: 15 January 2010, 14:45:11 »
weird, i noticed the same smell last night. could do with this little mystery cleared up
richardirv
« Reply #6 on: 15 January 2010, 14:51:37 »
Very Strange!!
« Reply #7 on: 15 January 2010, 14:51:57 »
its been damn cold for ages snow underneath some section of the car finally melting and causing a smell i guess? Not noticed myself  :-/
« Reply #8 on: 15 January 2010, 14:52:50 »
checked no animal crawled in to avoid the cold and is now a mangled mess?
M4DMATT
« Reply #9 on: 15 January 2010, 14:57:07 »
Sounds daft but also Check your exhaust for melted plastic bags/objects. My daily had the same thing last week and it was a polythene covered bit of cardboard stuck to the exhaust, someone must have used it to unstick themselves from the snow and i drove over it  ::)
V6 at about 4000rpm..........Probably the best noise in the world!
richardirv
« Reply #10 on: 15 January 2010, 14:57:06 »
Possible I suppose, I'd be more enclined to say its brakes binding but now I know others are experiencing the same I just don't know.
richardirv
« Reply #11 on: 15 January 2010, 14:59:07 »
Will definatly check under the car later, now the snow is melting and its a tad warmer! :y
unlucky mark mv6
  • tipton,west mids
« Reply #12 on: 15 January 2010, 17:19:46 »
Me too have noticed the smell of burning rubber coming from under the car while the snow has been down,but just put that down to tyres spinning. :-/
richardirv
« Reply #13 on: 15 January 2010, 17:22:01 »
So is your smell coming from the back then cos mine is from the front  :-/
« Last Edit: 15 January 2010, 17:22:12 by richardirv »
« Reply #14 on: 15 January 2010, 17:38:55 »
Someone on OOF recently posted re this - to do with salt mixture burning on cats.  Have to say noticed it with both ours - both have newish aux belts and tensioners.  Belt and all pulleys not unduly hot after a run but smell definately stronger down by both front wheels.
Will try & find other post when i get home.
Page created in 0.027 seconds with 14 queries.
