Author Topic: Key Fob Battery Replacement  (Read 1367 times)
panderson
  • Ayrshire, Scotland
« on: 16 January 2010, 11:18:20 »
Recently, the action of the remote central locking has been getting poorer (several presses right up against the window required to unlock/lock the car). I was thinking that  I need to replace the battery in the key fob & have obtained the type suggested on here.
However, I'm b*ggered if I can work out how to access the fob to swap the battery. Has anyone else done this that can offer some advice?
I'm sure I also read somewhere that this operation must be completed within a time limit to prevent loss of memory(?)
Martin_1962
Re: Key Fob Battery Replacement
« Reply #1 on: 16 January 2010, 12:03:07 »
Lever key off the fob - on hte back there is a clip. Use a small screwdriver
THen lever apart the fob where the key used to be and there is the battery
panderson
« Reply #2 on: 16 January 2010, 12:43:34 »
Thanks Martin :y
