Author Topic: my motor wont start  (Read 2834 times)
Davie
  • AYR/AYRSHIRE
my motor wont start
« on: 14 January 2010, 17:20:28 »
hi all, i own a 2.0ltr "M"reg. car was running rough so my mate put it on machine . Air flow mass meter and Crank Shaft Sensor were at fault. Brand New Parts were purchased and fitted now car wont start please help.
Re: my motor wont start
« Reply #1 on: 14 January 2010, 17:33:46 »
[movedhere] Test Zone [move by] Jimbob.
« Reply #2 on: 14 January 2010, 17:34:54 »
unfortunately youve probabaly wasted a bit of money...
the MAF error is often shown as a red herring along with the crank sensor.
Was the new one known good?  could be dead on arrival.
do the paperclip test (as per link in my signature) and post back the results.
« Reply #3 on: 14 January 2010, 17:41:37 »
did you use a geniune crank sensor?
Davie
  • AYR/AYRSHIRE
« Reply #4 on: 14 January 2010, 17:42:08 »
MAF was brand new from local motor factor and Crank sensor new from vauxhall dealer
« Reply #5 on: 14 January 2010, 17:57:28 »
Try starting it with MAF sensor diconnected.
Davie
  • AYR/AYRSHIRE
« Reply #6 on: 14 January 2010, 18:02:49 »
Tried That too. The wierd thing is if i put on an old crank sensor it bangs and clanks all over the place when trying to start it as if timing is miles out BUT it eventually starts although its rough and under powered . The NEW crank sensor allows it to turn over smoothly but will not start.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #7 on: 14 January 2010, 18:27:03 »
you need to get a mark 1 crank and cam sensor as the new type will let you turn engine but dose not give the correct signal, they are cheaper then the new type. can get both  for under £60. but have to be mark1. :y try these when there web page is working :yhttp://www.carpartsconnexion.com/vauxhall/default.asp
« Last Edit: 14 January 2010, 18:35:31 by Russell_Hill »
Davie
  • AYR/AYRSHIRE
« Reply #8 on: 14 January 2010, 19:12:43 »
Is that why i dont get spark and if so has vx sold me the wrong sensor although they only list 1 for my car
rustym95
« Reply #9 on: 14 January 2010, 21:08:03 »
there are two types mrk1 and mrk2 there is only a few places that you can get mrk1's from, as mine is mrk1 as well, the web address that left in post is the only place found that sell both types best to ge them changed at same time cam and crank so price is under £60. i was in same boat as you but found that there is two types they both have the same number as well but you have to explain that it is the mark 1 type and not 2, mark 2 is 1997 think. :y
« Last Edit: 14 January 2010, 21:54:38 by Russell_Hill »
« Reply #10 on: 14 January 2010, 23:07:29 »
Early sensor up to 14194716..........90458251
Later sensor from 14194717-31000001...........9174621
90458251 £59.50 £53.56 £46.32
9174621 £35.90 £32.36 £27.93
 Prices are retail, trade and trade club + vat
« Last Edit: 14 January 2010, 23:10:40 by RobG »
rustym95
« Reply #12 on: 15 January 2010, 10:10:05 »
husky jim
  • rotherham
« Reply #13 on: 16 January 2010, 12:31:05 »
just changed my crank sensor and that wont start now >:(
rustym95
« Reply #14 on: 16 January 2010, 16:21:50 »
PM sent  :y
