Author Topic: suspension noise and oil leaks  (Read 966 times)
christof
  • lincs
« on: 18 January 2010, 09:41:16 »
recently noticed driving on our local bumpy roads i get a suspension noise a knock i suppose . Driving on perfect roads nothing (not many of those in Lincs)  shockers seems ok no springs broke any ideas rolol bar bush maybe ??
i have developed a slight oil leak any obvious problems with these engines cant see anywhere obbvious where it could be from .  Start and let it run for 25 mins no leak rocker gasket ok   any ideas
engine in 2.2 sport 2002 128000 miles(just run in)
cruisetopoland
  • UK
Re: suspension noise and oil leaks
« Reply #1 on: 18 January 2010, 11:32:53 »
Posted same question recently as mine doing the same knocking-it appears that it is not possible to tell springs are broken until removing and a broken spring is a likely issue  OOFer welung666 looking at mine next weekend... :y
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #2 on: 18 January 2010, 11:37:47 »
Try to listen exactly the region the noise is coming from. Check the obvious, link rods, in my case it turned out to be the shock absorber mount.
