Author Topic: front brake pads  (Read 3530 times)
ryan martin
  • braintree essex
front brake pads
« on: 17 January 2010, 14:44:18 »
hi guys
got to change my front pads but cant seem to find the guide on here.
if any one can point me in the right direction id be greatful
also do i have to replace the wear indicators or are these already in the box with the pads
many thanx
ryan :-/
Re: front brake pads
« Reply #1 on: 17 January 2010, 15:03:49 »
Dead easy mate - wheel off, undo bottom 13mm bolt (on bottom slide of caliper), remove wear indicators (these will probably break), swing carrier up, pads out, new pads in, swing carrier back down, fit new 13mm bolt (should be new ones in with new pads) and torque, fit new wear sensor, wheel back on.  Don't forget to pump brakes till pedal hard.
New sensors do NOT come with pads - you will need to buy seperately.
15 mins a side.
HTH :y
« Reply #2 on: 17 January 2010, 15:05:42 »
15 mins a side.
HTH :y
And don`t forget to move pistons back so new pads fit :)
« Reply #3 on: 17 January 2010, 15:08:15 »
15 mins a side.
HTH :y
 :y :y :y goes without saying  :-[
ryan martin
  • braintree essex
« Reply #4 on: 17 January 2010, 15:09:48 »
thanks lads great help its it worth getting vauxhall pads or pattern part
« Reply #5 on: 17 January 2010, 15:14:29 »
Get Vx pads mate - found pattern pads no good for front but ok for rears.  Fronts around £14 on TC
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #6 on: 17 January 2010, 17:14:35 »
If you have any problems with push the pistons back, use a G-Clamp with an old pad and gently tighten it...
hotel21
  • The Kingdom of Fife
« Reply #7 on: 17 January 2010, 17:17:33 »
I normally just make carefull use of a large screwdriver with the old pads still in place to push the pistons back.  Take care on the edges of the discs though....   :y
Also, ensure that there is sufficient space in the fluid header tank to take the displaced fluid or crack open the bleed nipple to expell it.   ;)
« Reply #8 on: 17 January 2010, 18:02:03 »
...oooh.sucks teeth and shakes head...if they are that stiff there is a problem, make sure the fluid has somewhere to go with the res cap off or the bleed nipple open as mentioned, also possible a dust or fluid seal is damagad and jamming the piston.
 G clamp will most certainly do the job but last resort imo, you need to feel whats going on. Special tools for this work on a similar basis but for the omega these should not be needed ime.
 There is a block moulded into the back of the caliper that can be used with mole grip jaws to sqeeze the piston back in if it does get stuborn, but you should be able to sqeeze the caliper over on its sliders by hand while still mounted if all is in order. It will be stiff but possible, just.... :y
« Reply #9 on: 18 January 2010, 08:16:17 »
Now I would ALWAYS open the bleed nipple before pushing the piston back, massively reduce your chance of reversing the master cylinder seal.
gets rid of the oldest most knackered fluid too.
obviously bleed brakes as well when you are done, make sure your are rid of any air.
« Reply #10 on: 18 January 2010, 09:36:01 »
And the guide is in Maintenence Guides, also includes changing discs (just ignore those parts if you're just doing pads)
ryan martin
  • braintree essex
« Reply #11 on: 18 January 2010, 14:16:38 »
now do i have to change the wear sensors coz just been quoted £71 each but vauxhall ouch
« Reply #12 on: 18 January 2010, 14:20:44 »
HOW MUCH!!!!
sensors are under a tenner each
edit:
Omega        Part Number        Retail Price        Normal Trade        Trade Club
Brake lining wear sensors
All models                                        90495144       £10.20       £9.20       £7.71
« Last Edit: 18 January 2010, 14:21:38 by jimbob »
« Reply #13 on: 18 January 2010, 14:22:35 »
hmmm £71, versus 7 pound 71......think you may have misheard....
ryan martin
  • braintree essex
« Reply #14 on: 18 January 2010, 14:34:09 »
nope he checked again and still £71 each just had a thought he asked if it had abs bet he quoted me for abs sensor not wear sensor does anyone have the part number for the wear sensor many thanks
