Author Topic: Chaning the Auto Gearbox oil  (Read 2073 times)
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« on: 24 January 2010, 10:40:59 »
I have read the guide on checking and topping up the level of the Automatic Gearbox but I cannot find any advice on how to change the oil.
Anyone any idea?
Thanx
Re: Chaning the Auto Gearbox oil
« Reply #1 on: 24 January 2010, 10:46:28 »
As per top up guide, but you need to drop both sumps to remove the oil ..... carefully! :y You'll only remove about half of the total ATF as the rest will stay in the torque converter.
Bionic
  • Leicester
Q
« Reply #2 on: 24 January 2010, 10:59:04 »
Bummer!
How difficult is that to do because my bionic legs do not work as they should, they tend to get in the freekin way most of the time. I am limited to either sitting, standing up or lying down - aint no halfway point!
As my ATF oil is a brown colour I suppose I shall have to bite the bullet and do it then? What colour should it be?
Might even try a bit of a mod and see if I can put a drain plug into the sumps while they are off!
Re: Q
« Reply #3 on: 24 January 2010, 11:01:16 »
Brown isn't good  :(, it should be a nice red colour    ;)
Bionic
  • Leicester
« Reply #4 on: 24 January 2010, 11:12:12 »
Lovely, just what I thought.
Hey ho and away we go then!
Can the old oil be siphoned or pumped out somehow?
I have a drill operated pump and a 500cc syringe that I can convert to take a smaller bore suction tubes.
Welung666
« Reply #5 on: 24 January 2010, 11:12:55 »
Bionic if you fancy a day trip over to near Brum I'll give you a hand, I'm getting a dab hand at those auto boxes now ;) :y
Bionic
  • Leicester
« Reply #6 on: 24 January 2010, 11:20:16 »
Cheers wellung666, I will bear that in mind but will have a go with my ideas first. If they work I shall probably post a how to.
I cannot see why it should not be possible to 'suck' it out with a bit of caution taken.
Freekin design bleeders should have put a sump plug in anyway.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 24 January 2010, 11:22:36 »
if you can lye dwn its not to hard a job. as said both sumps off. and you need about 7ltr to refill. and then run it up just go thro the gears 1 at a time then undo fill plug "with engine running then top up till it runs out off fill hole"
Hoof'land storeman.
Bionic
  • Leicester
« Reply #8 on: 24 January 2010, 11:31:27 »
ok, I will give it a buzz during the week and see how I get on.
Cheers all.
guncharmer
  • York
« Reply #9 on: 24 January 2010, 11:49:17 »
i want to change my autobox oil (mileage 71K) purely for piece of mind and to make me feel better but i havnt come across any info yet on how to empty ALL the old oil out,so how do you drain the torque convertor as well?
biggriffin
« Reply #10 on: 24 January 2010, 12:34:36 »
if you go and look on the maintance guides theres a how to on there. am sure someone a bit clevery than me will post the link up.
Hoof'land storeman.
« Reply #11 on: 24 January 2010, 13:53:14 »
Be thankful that your engine has a sump drain plug, SWMBO's Smart doesn't have one!
