Author Topic: No Speedo, ABS, TC or Crusie Control  (Read 1531 times)
The Moose
« on: 20 January 2010, 10:29:50 »
Hi I’m a new member and I just bought a 1998 Omega GL 2.5 Estate.
I got it really cheap because neither the speedo, ABS, TC or the Crusie Control is working at the moment.
After searching this forum my first thought was that the ABS ECU had given up, but now I’m not sure anymore, because none of the warning light is on (ABS, TC).
Everything else in the dash is working, petrol, temp and rev counter.
If I press the TC button nothing happens….
Any ideas, before I start ordering spare parts…..
Re: No Speedo, ABS, TC or Crusie Control
« Reply #1 on: 20 January 2010, 10:39:51 »
Does sound like the ABS ecu is knackered. TC only lights up when switched off. Does the ABS illuminate when ignition switched on., if not bulbs have probably been removed. Ecu can be refurbed for about £120/140. Or source one from same spec model. i.e. engine/gearbox. Failing that I believe you can use any ABS Ecu but it would need to be re-set with a Tech II. Not 100% certain though
« Reply #2 on: 20 January 2010, 11:04:59 »
ABS ECU knackered mate.  If going 2nd hand route you need one from exactly same model and approx same year to avoid need for Tech2 work.  Helpfully the part nº is on the bottom of the ecu!!
« Reply #3 on: 20 January 2010, 11:59:49 »
hmmmm.....if the ABS ecu was failed....I would expect the light to be on.....are all the fuses etc ok?
The Moose
« Reply #4 on: 20 January 2010, 17:54:01 »
I got home from work and checked the warning lights in the dash, and you’re right, the bulbs were gone. The seller claimed to have no knowledge about this….yea right…
Checked the broker and found an ABS ECU from a 1997 Omega with the same engine and gearbox. Only £97 including freight.
Thank you all for the inputs and help!
Cheers
« Reply #5 on: 20 January 2010, 22:22:29 »
Cheers
Send it here:l
They will re-furb for 100 sobs and give you a 2 year warranty
http://cgi.ebay.co.uk/Vauxhall-Vectra-Omega-ABS-Pump-ECU-Modulator-Module_W0QQitemZ390062715978QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item5ad18cb44a
GArlington
  • London, UK
« Reply #6 on: 24 January 2010, 11:37:10 »
Are you anywhere around London?
If yes you can rummage around my 1999 2.5 and take any parts you want or need...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 24 January 2010, 12:30:50 »
if you go onto google and put in "omega abs pump" a company in derby comes up they recon your old unit by return of post fof £100.
Hoof'land storeman.
« Reply #8 on: 24 January 2010, 14:09:54 »
Another company is BBA Reman ... did an excellent job on mine a few years back :)
