Author Topic: Storing the car - 3 months etc  (Read 2695 times)
ScaniaV8
  • Luton, Bedfordshire
« on: 26 January 2010, 09:49:14 »
Hi,
Is there anything special that  I need to consider before storing the Miggy car (i.e parked up/non use) for a period of 3 or 4 months... battery disconnect, Oil and coolant considerations, other electrical  etc etc.  Car just SORN whilst carrying out some engine related/MOT repairs
All advice appreciated..
cheers   :-/
Ken L
  • Sheffield, South Yorkshire
Re: Storing the car - 3 months etc
« Reply #1 on: 26 January 2010, 09:52:19 »
Parked up outside for this time? or in a garage? will you be moving it about if you're working on it during this time?
« Reply #2 on: 26 January 2010, 10:32:34 »
3 months isn't too long. Take the battery out and give it a charge periodically to stop it going flat. Ideally give it an oil change beforehand if the oil is old as this removes acids from the crankcase. Coolant should be kept fresh as always.
Don't be tempted to start it just to run it. Does more harm than good to keep starting an engine without giving it a workout to get everything hot, IMHO.
If it's going to be sat outside, a good wash and wax beforehand to protect the paintwork.
Ken L
« Reply #3 on: 26 January 2010, 10:45:41 »
Especially if outside, wrap the brake discs/calipers up with plastic bags to protect from the elements, and choc the wheels and leave the handbrake off.
ScaniaV8
« Reply #4 on: 26 January 2010, 11:57:34 »
Cheers Guys thanks for the advice..very much appreciated.
I'm actually working in Sweden full time but manage to normally get back once a month usually but I will be quite busy during next 3-4 months so my last visit back is this weekend. I just wanted to avoid flat battery and other electrical/mechanical irritations whilst the MIG is laid up. It will be parked outside unfortunately, open to all the elements :-(.
unlucky mark mv6
  • tipton,west mids
« Reply #5 on: 26 January 2010, 12:32:01 »
If the car is to be stored outside,it may be worth buying one of those solar panels that clip on to your sunvisor,and plugs into your fag lighter,to provide the battery with a trickle charge,but dont know if they are any good,just something i noticed in a mag,and maybe someone else can comment on them. ;)
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
« Reply #6 on: 26 January 2010, 12:52:24 »
I've got one of those solar chargers, and I think it helps. The car seems to start a bit more smartly after standing for 3-4 days, and doesn't throw up those odd messages so much on starting.
Try to go for one with a slightly higher output, they range from 1 watt up to about 2.5 watt (they do go higher but start to cost silly money). My one is 1.2w but I am planning on buying a 2.4w and using the 1.2w on my motorbike.
You will also need to check that the socket in the car stays live with the ignition off, or wire directly to the battery.
« Reply #7 on: 26 January 2010, 13:07:08 »
The Omega one doesn't, so it will do no good plugged into the lighter socket.
If connecting anything to the battery, you must include a fuse rated appropriately to protect your wiring, as close to the battery as possible. :y
In this case, may as well remove the battery IMHO.
djac
  • West Sussex
« Reply #8 on: 26 January 2010, 13:12:27 »
So it's only us lucky Elite owners with the 12v accessory socket at the back of the console which stays live, then? :)
« Reply #9 on: 26 January 2010, 13:13:07 »
should only stay live for a short time (15 mins) after engine switch off  :y
« Last Edit: 26 January 2010, 13:16:23 by jimbob »
Dave Elite
  • Ellesmere Port
« Reply #10 on: 26 January 2010, 13:16:02 »
Or leave it in park
« Reply #11 on: 26 January 2010, 13:24:04 »
Certainly true on my facelift. Front socket is switched by ignition key, rear has a timer.
Very good idea. :y
djac
  • West Sussex
« Reply #12 on: 26 January 2010, 13:24:32 »
"...should only stay live for a short time (15 mins) after engine switch off.."
Darn! And I was so sure it was making a difference! :(
Perhaps it is just in my head - like the voices... :D
Oh well, I can save some money now, I'll just move the panel I've got onto my bike...
« Last Edit: 26 January 2010, 13:29:34 by jimbob »
« Reply #13 on: 26 January 2010, 13:29:16 »
Could always check....they have been known to go faulty  :y
« Reply #14 on: 26 January 2010, 13:31:18 »
and for clarity, iirc...
Its not just elites have the rear socket, think they all do.
facelift should stay live for 15 mins after switch off
prefacelift should be instant off.
