Author Topic: Clearing fault codes  (Read 990 times)
Pobble
  • Bromley, Kent
« on: 04 February 2010, 13:48:33 »
I have just replaced the crankshaft sensor based on a code19.
It has not made any difference and so I want to clear the code. Is there any way I can do this or is it a tech2 job?
Re: Clearing fault codes
« Reply #1 on: 04 February 2010, 13:49:19 »
tech2 or other diag computer sorry.
it 'may' clear after 20? clean starts, but may not.
was it a new genuine sensor, or pattern?
« Last Edit: 04 February 2010, 13:49:53 by jimbob »
geoff
  • thornaby,stockton on tees
« Reply #2 on: 04 February 2010, 15:08:00 »
short the two pins
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
To clear the fault codes, simply remove the battery leads for a few minutes and then reconnect.
got this from following site
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
worked on mine :y :y :y :y
« Last Edit: 04 February 2010, 15:09:23 by geoff »
