Author Topic: leaky injector on TD  (Read 4154 times)
unlucky alf
  • worksop, notts
« on: 09 February 2010, 17:37:38 »
for the last few weeks ive been smelling a strong smell of diesel, ive had a look today & found diesel running down the sump & dripping onto the floor, it seems like the no3 injector is weeping, is it just a matter of tightening or something more sinister as i know no3 is the one with a chip in it, i believe a special socket is required which i dont have, any help would be appreciated. :y  oh & the little rubber pipes look o,k.
MickAP
  • South Derbyshire
Re: leaky injector on TD
« Reply #1 on: 09 February 2010, 17:42:10 »
That's no4 I believe. Try nipping it up first see if it seals.
unlucky alf
  • worksop, notts
« Reply #2 on: 09 February 2010, 18:01:59 »
cheers mick, its the one with a wire going into it so i guess its the expensive one ;), i`ll try & nip it up if i can get to it :D
hoofing it
« Reply #3 on: 09 February 2010, 18:18:29 »
4
you might need to replace the leakoff pipes if you start the engine and shine a torch on it you should see it easy fix or nip up the nut its a 17mm spanner.
No 4 is the sensor
Essex Pete
  • Woodford, Essex
« Reply #4 on: 09 February 2010, 19:16:15 »
I rekon its more likely to be the leak off pipes than the injector.  If the injector is leaking, then you will see a pool of diesel at the bottom of the injector with bubbles of air escaping from around the thread.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 09 February 2010, 19:31:13 »
Should be leak-off pipes or the injector pipe.
Welung666
« Reply #6 on: 09 February 2010, 20:07:01 »
I've got a length of leak off here if you need a bit to try Should be enough to replace the sections between all 6 injectors but there isn't enough to go back to the pump as well.
unlucky alf
  • worksop, notts
« Reply #7 on: 09 February 2010, 21:11:05 »
cheers chaps, i`ll take a good look at it tomorrow, is the leak off pipe anything special or will vacuum pipe do the job [if you know what i mean], & thanks for the offer welung but it might be a bit far to travel for a bit of pipe ;) :y
Welung666
« Reply #8 on: 09 February 2010, 21:15:14 »
I was thinking Royal Fail rather than a visit  ::) Different to vacuum hose as it needs a certain chemical resistance with carrying diesel ;)
« Last Edit: 09 February 2010, 21:16:12 by Welung666 »
MickAP
  • South Derbyshire
« Reply #9 on: 09 February 2010, 21:15:57 »
I got some from my local motor factors, you need diesel leak off pipe, braided rubber. :y
Mick
hoofing it
« Reply #10 on: 09 February 2010, 21:17:17 »
any local m/factors or halfords costs less than a tenner simple to do you get enough for all 6 in the pack. :y
unlucky alf
  • worksop, notts
« Reply #11 on: 09 February 2010, 21:23:26 »
cheers once again chaps, i`ll go visit my local factors & do the lot as the stuff on it doesnt look like its braided anyway :-/, ive only just replaced my fuel lines as they rotted at the back & leaked & now this >:( aww bugga >:(
unlucky alf
  • worksop, notts
« Reply #12 on: 10 February 2010, 12:57:25 »
here is the update, ive changed the leak off pipes & cleaned it all down, but i still have the leak from no4 & no5, so any suggestions what to do next as i dont have the special socket for the no4 injector  :'(.
hoofing it
« Reply #13 on: 10 February 2010, 18:53:38 »
where  exactly is the leak. :question
is it below the leak off pipes on the ridge
unlucky alf
  • worksop, notts
« Reply #14 on: 10 February 2010, 21:33:06 »
yup it does seem to be where it screws in, please tell me it just needs tightening :-/
