Author Topic: Rusty bores  (Read 2268 times)
ScottieMV6
  • Swinton, Manchester
Rusty bores
« on: 15 February 2010, 11:05:45 »
Just had a proper look at the engine in the car before attempting to put the heads back on and there is some light surface rust in the bores :( :(
Will this be a major problem? Should I rub it off with some fine emery paper or just leave it?
I'd rather be scared to death than bored to death!!
Re: Rusty bores
« Reply #1 on: 15 February 2010, 11:07:05 »
I'd use a bit of wet & dry
Re: Rusty bores
« Reply #2 on: 15 February 2010, 11:07:52 »
It'll be fine mate, should in fact wipe off, if not, very fine wet and dry  :y
Re: Rusty bores
« Reply #3 on: 15 February 2010, 11:11:07 »
I would say try to rub it off with a scotchpad soaked in paraffin / WD40 etc. first. Don't really want to get grit from an abrasive paper in it now it's cleaned up and being reassembled.
Re: Rusty bores
« Reply #4 on: 15 February 2010, 11:12:17 »
Yeh, wipe it over with a green pan scourer.
Should be fine
Re: Rusty bores
« Reply #5 on: 15 February 2010, 14:24:21 »
Wouldn't recomment wet 'n dry on engine in situ - difficult to remove all abrasive material!
As said use a scotchpad (or as Mark suggested a green pan scourer) soaked in paraffin or WD40.
ScottieMV6
Re: Rusty bores
« Reply #6 on: 15 February 2010, 17:26:34 »
Thanks guys. Thats my work for tomorrow sorted then :y
Re: Rusty bores
« Reply #7 on: 15 February 2010, 17:30:55 »
You've booked nice weather then?  :y
ScottieMV6
Re: Rusty bores
« Reply #8 on: 15 February 2010, 17:35:40 »
Yes and if it doesn't materialise I am now blaming you! ;D ;D ;D
Re: Rusty bores
« Reply #9 on: 15 February 2010, 18:18:16 »
Yes and  .....
Good! That means I can clear the inside of my Omega out, and if I have time I might do her Smart  ::) shouldn't take too long!  ;D
neonomega
  • southampton
Re: Rusty bores
« Reply #10 on: 15 February 2010, 20:39:04 »
hi m8 i had same problem i used very smooth wet and dry i also used a bit of light oil to rub around and everything is good  :y
