Author Topic: My car thinks it's 68 degrees outside!  (Read 2687 times)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« on: 18 February 2010, 16:54:31 »
Hi all,
Just driving home from work this evening, got the customary flashing waring of 0.5 degrees outside on the mid... however, on the way home, it started reading 68 degrees! Varies up and down a couple of degrees, but of course, the climate control thinks its hot outside, so have to crank that up to keep warm  :(
Engine temperature is normal, car appears to be running okay.
Figure its the outside temperature sensor up the creek - firstly, can anyone tell me where it is on the Omega (and is it easy to change), and secondly, does it sound like the right symptoms, and thirdly, how much should I be paying?
Thanks in advance! :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
Re: My car thinks it's 68 degrees outside!
« Reply #1 on: 18 February 2010, 16:56:50 »
very easy to change, open the bonnet, look down, its central on the bumper.
about £6 from vauxhall for a new one.
it does affect your climate operation as well.
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #2 on: 18 February 2010, 17:00:38 »
Thanks for the quick reply - I'll give the stealers a bell!  :y
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #3 on: 18 February 2010, 17:35:36 »
Mine did exactly the same thing recently, very easy to change...
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #4 on: 18 February 2010, 19:43:34 »
Cheers!
Just ordered one from Autovaux - £3.85  :y
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #5 on: 18 February 2010, 20:38:49 »
Did you have trouble with the connector on yours too under the bumper?? I seem to recall that can cause issues too reading in the past??
Weds
  • Chatham, Kent
  • My other hobby
« Reply #6 on: 18 February 2010, 20:58:09 »
No none at all, straight plug and play... Got to be one of the easiest jobs on the Omega..
Rob James
  • Sheffield
« Reply #7 on: 19 February 2010, 10:11:46 »
I've replaced my temp sensor and it still reads either a fault or -30 (which then turns off air con). I've tried cleaning the connection at both ends with no joy, not sure what to try next?
maria
  • Derbyshire
  • I'm proud to be welsh :)
« Reply #8 on: 19 February 2010, 10:34:53 »
Hi all,
I wish it was 68 degrees outside  ;D
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #9 on: 19 February 2010, 19:31:15 »
Hi all,
How nice would that be! :)
shay oneill
  • coalisland n.ireland
« Reply #10 on: 20 February 2010, 02:23:14 »
we wish lol
