Author Topic: mystery water in rear passenger footwell  (Read 1490 times)
l.t
« on: 17 February 2010, 20:32:27 »
hi there is water in the rear passenger footwell of my 99 2.5 cdx omega saloon. it has soaked through the carpet . ive looked underneath and cant find any holes.... any ideas?
cheers
l.t
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Re: mystery water in rear passenger footwell
« Reply #1 on: 17 February 2010, 20:40:29 »
Hi, clean or mucky water?
Might be door seals around the arch?  :-?
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Welung666
« Reply #2 on: 17 February 2010, 20:40:57 »
Possibly 2 places of ingress. Do you park on a slope? If so nose up or down?
l.t
« Reply #3 on: 17 February 2010, 20:44:21 »
hi its not the door seal ive checked that. i park on a slight slope nose down.
cheers
l.t
Welung666
« Reply #4 on: 17 February 2010, 20:48:47 »
Check the skuttle drains are clear and as a test sit in the back and get someone to pour water on the sunroof, see if the water level goes up. Possible the rear drain hose has come off the sunroof.
« Reply #5 on: 17 February 2010, 20:49:05 »
Could be the scuttle drain and its "old" water  .. bit odd if you park nose down .. but worth checking
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
or possibly the sun roof drains .. if you have a sun roof ??
Edit :  must type faster .. but I found the link ..  :)
« Last Edit: 17 February 2010, 20:49:41 by entwood »
l.t
« Reply #6 on: 17 February 2010, 20:53:41 »
will look at those guys . thanks
where are the drains for the sunroof located?
cheers
l.t
« Reply #7 on: 17 February 2010, 21:02:59 »
If you look in the sunroof well you can see them ... best thing to clean them with is old fashioned netcurtain hanging cable....  but DO NOT push hard .. the pipes are only a push fit on and it is easy to push them right off ... that then needs a sunroof removal to sort .... or so I've been told ...
Not actually done it, but I did clear my old omegas drains using said cable... slightly different problem mind ... on mine the well was flooding
Welung666
« Reply #8 on: 17 February 2010, 21:03:02 »
cheers
l.t
All 4 corners of the sunroof, 1 down each A post 1 down each C post. If it turns out to be one then most likely at the sunroof itself so it'll be a roof lining off job.
d737
  • Liverpool
« Reply #9 on: 18 February 2010, 11:54:38 »
Had the same myself, passenger side?, mine was a blocked drain skuttle, there is a good link somewhere on the site on how to clear.
l.t
« Reply #10 on: 20 February 2010, 15:57:06 »
where do the sunroof drains exit?
