Author Topic: Fault Code......... Do i repair or scrap??  (Read 1393 times)
Michael F
  • Hertfordshire
« on: 20 February 2010, 09:50:54 »
I have three fault codes that have come up on my 2002 2.2 CD.........
P1130 02 sensor circuit high voltage (Bank 1 sensor 1) C-30
P0170 Rich / Lean Exhaust C- 30
P1555 Throttle position sensor (TPS) load signal not plausible with engine load C-09
I have been told by my local garage that code P1555 will cause codes P1070 & P1130 to appear and to fix the problem they are quoting me £600 +.
Any guidance or information on this would be much appreciated as i have not got a clue what all this means  :-/
Cheers, Mick
unlucky mark mv6
  • tipton,west mids
Re: Fault Code......... Do i repair or scrap??
« Reply #1 on: 20 February 2010, 10:16:46 »
Cheers, Mick
Does the car still run ok michael?
Michael F
  • Hertfordshire
« Reply #2 on: 20 February 2010, 10:22:09 »
No, runs rough from cold and stalls until warm but then runs as if it were missing, revs drop without any movement of the pedal............ if that means anything to you?
« Reply #3 on: 20 February 2010, 10:23:49 »
OK, before resigning to a new throttle, clean out the breathers and the throttle body (guide in maint guides section)...
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 20 February 2010, 10:29:29 »
If the car ran ok,normally the ecu in vauxhalls have a tendancy to throw up old codes that was never cleared properly,but as for being quoted £600 i reckon they are out to rip you off mate,if i were you i would get one of the lads on here close to you to see if they can help you out,i never take my car to a dealer,and never will.If the truths known its probably only one of those fault codes thats causing the trouble,but has a knock on effect triggering others off. :y
Michael F
  • Hertfordshire
« Reply #5 on: 20 February 2010, 10:30:11 »
Cheers, i will try that today......... fingers crossed!!
Be gutted to have to get rid of it because of this problem but dont want to pay £600 + to my local garage seeing as they only think this may fix the problem..............
« Reply #6 on: 20 February 2010, 10:32:07 »
If they dont know if it will fix it, they haven't diagnosed it properly!!  With a good code reader (with live data), its an easy one to diagnose.
Michael F
  • Hertfordshire
« Reply #7 on: 20 February 2010, 10:37:50 »
I see......... well i'll give it a clean and see what happens and if need be maybe take it to a different garage..........
Cheers for the help
deadlydave
« Reply #8 on: 20 February 2010, 15:34:27 »
Like suggested, get someone with a good code reader to give it a once over, but I can tell you from experience, a duff ECU can throw codes up, leading you to go on a hunt for non faulty parts as well as making the car run poor, or not at all.
If it does turn out to be a faulty ecu (god forbid) there is a garage who is on ebay that can supply you with a replacement ecu, chips etc tailored to your car. costs about £250 or there abouts..  worth bearing in mind if this ever happens to you.
« Reply #9 on: 20 February 2010, 15:47:40 »
Clean the breathers and throttle body to start with......live data would possibly show a MAF issue....
« Reply #10 on: 20 February 2010, 20:07:53 »
Omega engine ECUs are so reliable, I would only even ever contemplate changing one as a last resort.
