Author Topic: abs tc speedo not working!!  (Read 1848 times)
karlus 693
  • Isle of Wight & Torquay
« on: 25 February 2010, 14:47:38 »
Hi Guys just been reading the standard problem with the abs tc light on and no speedo, and every thing points to abs ecu change. but mine is intermittent some days its fine others not!  Could there be something else going on or is this normal before it stops completly? 2.5 v6 1999.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: abs tc speedo not working!!
« Reply #1 on: 25 February 2010, 15:01:10 »
Exactly the same is happening with mine.  I'm thinking the ABS sensor's could do with a clean, although I do have a spare ECU just in case.
Mine tends to be fine when I first start in the morning, then after a short while, the lights come on, steering gets heavy and no speedo.
I plugged it into "My Naff Code Reader" and the Wheels were all reading the same speed when hacking it around the block though.
« Last Edit: 25 February 2010, 15:01:53 by Broomies_Mate »
amba
  • Medway towns
    • German V6
« Reply #2 on: 25 February 2010, 15:01:47 »
Its in its last "death throws" and will possibly continue like that for some time ,or drop stone dead.
Loads of posts regarding removal/refurb.....expect refurb cost of circa £130 + and from my own experience BBA reman seems to be the most reliable for repair and turnround time.....where are you located ??
karlus 693
« Reply #3 on: 25 February 2010, 15:04:09 »
I am in sunny Torquay!!!
« Reply #4 on: 25 February 2010, 17:52:01 »
Exactly what I had to start with ....  slowly got worse .. then eventually was a permanent feature .. :(
BBA-Reman refurbed and returned the ECU in 5 days ... :)
« Reply #5 on: 25 February 2010, 17:54:22 »
Probably worth checking all sensors gapped right, and no filings built up on them (free to do).  But I think we all know where this is heading  :'(
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #6 on: 25 February 2010, 17:59:53 »
Bugger.  Perhaps I dont have a replacement ECU as previously hoped.
My breaker Omega is a 1995 and mine is a 1998.  Both 3.0 Auto.
Any suggestions as to whether it might work?  In fact, I just know it wont.
"My Naff Code Reader" says mine is ABS 5.3/5.4 (+TC)
Whereas the older type is ABS 2SE (+TC)
« Reply #7 on: 25 February 2010, 18:12:48 »
it wont work
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #8 on: 25 February 2010, 18:29:31 »
Dont suppose you would know which years would work?
I take it the ECU has to be from a Saloon, not an Estate?
"My Naff Code Reader" suggests the ABS ECU is the same all the way from 1998 onwards, but I fancy they would be different on facelift models?  When did the 3.0 cease production?
« Reply #9 on: 25 February 2010, 18:33:10 »
Ignore "My Naff Code Reader", its good at lies.  Also, all post 98 use 5.3(+tc on v6). But they all carry different configs
Go for the ident code.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #10 on: 25 February 2010, 18:36:31 »
Cheers for your help!  :y
