Author Topic: Mouldy sunroof  (Read 1808 times)
andy72
  • Newcastle
Mouldy sunroof
« on: 25 February 2010, 18:02:02 »
How do you get rid of the green alge mould around the outside of the sunroof. It's on the outside on the black rubber stuff that seals the glass. It's not taken over yet but is starting to look a bit yuk
hotel21
  • The Kingdom of Fife
Re: Mouldy sunroof
« Reply #1 on: 25 February 2010, 18:11:38 »
Powerwasher?   Soap and a sponge?  :-/
Personally, I have to use a powerwasher at work to clean some very grubby cars sometimes and a blast with a powerwasher works wonders.  Just need to take care where the fallout ends up......   ;)
Re: Mouldy sunroof
« Reply #2 on: 25 February 2010, 18:15:58 »
one of wd40's best uses ;)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Mouldy sunroof
« Reply #3 on: 25 February 2010, 19:51:28 »
mould killer, patio cleaner works, dab on with a cloth give it an hour or so, wash off, should go gray when its dead. and dont come back for 2years even if under a tree.
mantahatch
Re: Mouldy sunroof
« Reply #4 on: 25 February 2010, 19:58:09 »
I actually find an old toothbrush is great for cleaning around the sunroof. It is also very useful around the lights and any small gap.
HTH
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: Mouldy sunroof
« Reply #5 on: 25 February 2010, 20:13:02 »
HTH
and dont forget to to rinse it before returning to the wifes wash bag  ;D ;D ;D ;D ;D ;D ;D
Just chilling in the sun. I wish back in the rain like everybody else
Hannah Judes Dad
    • the misses round the bend
Re: Mouldy sunroof
« Reply #6 on: 25 February 2010, 20:45:03 »
HTH
especially if you also use it to clean the loo  :D
Re: Mouldy sunroof
« Reply #7 on: 25 February 2010, 22:38:27 »
What ever you use I would try and rub it in 1st and let it soak in to try and loosen it and the jetwash it all off.
mudflap
  • NW London UK
  • My Green Goddess
Re: Mouldy sunroof
« Reply #8 on: 26 February 2010, 06:56:21 »
Soap and water with a sponge should get the worst off, and use a credit card or small brush for scraping off any stubborn algea - never use a jetwash, or you'll cause the sunroof seals to fail and leak into the car -  jetwashes cause all sorts of problems, good old-fashioned elbow grease is always the best way  ;)
« Last Edit: 26 February 2010, 06:58:58 by mudflap »
If it's got tits or wheels  it's bound to give you trouble
Re: Mouldy sunroof
« Reply #9 on: 26 February 2010, 08:28:19 »
Sunroof seal aren't fully water tight, they have a felt-like finish. The drains at each corner are there to get rid of what water does go past the seal.
Re: Mouldy sunroof
« Reply #10 on: 26 February 2010, 08:31:29 »
mines a bit like this, was gonna use milton fluid and a toothbrush.
Re: Mouldy sunroof
« Reply #11 on: 26 February 2010, 08:54:22 »
Nought to use by giving it a squirt of wd40 - thats what I use to remove the grren stuff from my windows.  OK, you have to wash the car a couple of days later ;D
Re: Mouldy sunroof
« Reply #12 on: 26 February 2010, 09:03:50 »
Milton can have a slight "bleaching" effect, so could discolour the "felt" portion.
I just use soapy water and a toothbrush, as it appears others do ..  :)
Re: Mouldy sunroof
« Reply #13 on: 26 February 2010, 09:14:34 »
Ill be advised then, as I havent tried it yet  :y
