Author Topic: climate control works sometime doesnt?  (Read 1144 times)
l.t
« on: 01 March 2010, 08:49:35 »
hi my climate control on my 99 2.5 manual sometimes works ... nice and warm , go on a run its fine . stop the car and get back in and its just cold air. any ideas?
cheers
l.t
Re: climate control works sometime doesnt?
« Reply #1 on: 01 March 2010, 09:13:02 »
does the sampling fan work ok?
there is a little 'vent' on the climate panel, when working it should be powerful enough to hold a small piece of tissue to itself.
If not, the car may think it is hot enough already, so not supply hot air...
sometimes a clean helps, otherwise the fan can be replaced with a small pc fan.
Steveplumb
  • Radstock, Near Bath
« Reply #2 on: 01 March 2010, 09:18:09 »
Is the blower working ok ? responsive to fan speed settings . Do any vents blow warm ,  Check L/H dash vent .  I recently had one of the flap control linkages fail , but as yours seems to be intermittent that doesn't seem so likely but may be worth checking
