Author Topic: Cold heater.....warm engine!!  (Read 1406 times)
Sixstring
  • Lydney, Gloucestershire
« on: 03 March 2010, 11:06:27 »
I'm sure someone has covered this before, so I apologise if this is an already answered question.
My temp runs as normal on the guage, but no heat in the car (Elite 3.0 est) giving the climate control only cold air. Am going to put in flushing liquid to try to clear up a bit, but am told only half the water will come out. Have a new thermostat and water pump if needed, but told its a B*stard of a job to do, and I don't have much time to fettle myself.
Can anyone advise me?
Thanks.
Mike.
Re: Cold heater.....warm engine!!
« Reply #1 on: 03 March 2010, 11:32:38 »
could start with a heater matix flush.....only need a hosepipe for that, guide in the maint section  :y
Kai
  • Oxordshire
  • Just useless
    • Omega elite 2000
« Reply #2 on: 03 March 2010, 11:41:27 »
Guess I just couldn't stay away for the fourth time....
2woody
  • Northumberland
« Reply #3 on: 03 March 2010, 11:52:00 »
check your heater valve hasn't been connected straight to vacuum.
star_whites
  • Rotherham
« Reply #4 on: 03 March 2010, 12:51:20 »
Have you tried resetting the system.
Turn the ignition key to standby and press and hold the auto and off button together. You will be able to hear the system resetting itself. Hold for about 15 secs then start the car and see what happens. It worked on mine  :y
GaryBC
  • Egham, Surrey
« Reply #5 on: 03 March 2010, 13:50:36 »
I found a fresh water flush did almost nothing to improve my heating - or even several, in opposite directions!
I gave mine a soak with kettle descaler. This helped in that tepid air is better than stone cold!
In the meantime, switch your aircon pump off. At least you'll not be getting chilled air!!
I'm bracing myself for a heater matrix change! There's a thread here for doing it through the o/s footwell.
« Reply #6 on: 03 March 2010, 14:02:03 »
Its not a guarantee'd fix....but a good, and free starting point.
especially if the car has had oil cooler failures, or radweld etc used in the past.  Doesnt take much to block em.
My car lived on radweld for a while, and still suffers the consequences with the matrix, a flush has warmed up many peoples heaters  :y
Sixstring
« Reply #7 on: 03 March 2010, 14:08:13 »
Thanks fellers, nothing ventured.....................!!
summers coming, won't need heat soon????
Yeah, right.
