Author Topic: Torque settings  (Read 1337 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
Torque settings
« on: 03 March 2010, 17:07:54 »
Can anyone give me the torque settings for the water pump, cam pulleys & tensioner, in FT LBs please.
2.2 Omega
Regards
    Dave
Re: Torque settings
« Reply #1 on: 03 March 2010, 17:32:37 »
As far as I can see from Haynes, which doesn't list a 2.2 so these are 2.0 figures ... .. :)
Coolant Pump bolts = 28 lbf ft
Camshaft sprocket bolts = 33 lbf ft
Camshaft thrustplate bolts = 6 lbf ft
Camshaft housing end bolts = 6 lbf ft
Timing belt tensioner bolts = 15 lbf ft
HTH
« Last Edit: 03 March 2010, 17:33:25 by entwood »
Re: Torque settings
« Reply #2 on: 03 March 2010, 17:45:13 »
all in the maint guides..
http://www.omegaowners.com/forum/YaBB.pl?num=1161698682
or check the index  :y
Re: Torque settings
« Reply #3 on: 03 March 2010, 17:54:27 »
He asked for lbf ft .... the guide is all Nm ..  :)
DaveA
  • Leicestershire
Re: Torque settings
« Reply #4 on: 03 March 2010, 18:09:55 »
HTH
THANKS
    I only understand real money :D :D :D  :y :y
Regards
    Dave
Re: Torque settings
« Reply #5 on: 03 March 2010, 18:20:30 »
HTH
THANKS
PMSL.....You have to pity the over 50's.  ;D ;D
DaveA
  • Leicestershire
Re: Torque settings
« Reply #6 on: 03 March 2010, 21:55:01 »
HTH
THANKS
 ;D ;D ;D ;D ;D ;D
Regards
    Dave
Re: Torque settings
« Reply #7 on: 03 March 2010, 21:56:54 »
HTH
THANKS
What you mean is you're a tight git who won't buy a new torque wrench  !!!!  Did Noah make the one you use ????
(probably not thinking about it .. that would be calibrated in talents and cubits !!  )
 ;D ;D ;D ;D ;D
« Last Edit: 03 March 2010, 22:00:08 by entwood »
Re: Torque settings
« Reply #8 on: 04 March 2010, 02:11:30 »
Is it one of those wooden ones?  :-/ ;D ;)
