Author Topic: steering idler  (Read 1094 times)
browner
  • HEREFORD
steering idler
« on: 06 March 2010, 10:55:08 »
how do i change the steering idler on a 2000 elite
Re: steering idler
« Reply #1 on: 06 March 2010, 11:09:26 »
check out the maintainance guide section.
link to the index in my signature  :y
MickAP
  • South Derbyshire
Re: steering idler
« Reply #2 on: 06 March 2010, 14:29:43 »
Easy enough job (well it was because even I have done this one). Trouble is it was a right pain to get off, plenty of brute force with a heafty lump hammer. There's not enough room to swing the hammer though, unless you've got it on a ramp.
It'll give in eventually though.
Mick
Varche
  • middle of Andalucia
    • Golf Estate
Re: steering idler
« Reply #3 on: 06 March 2010, 14:54:03 »
A bit of plus gas and hitting both sides simultaneously by using two hammers helps.
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: steering idler
« Reply #4 on: 06 March 2010, 15:13:36 »
More comenly known as "The ball joint from hell"
Lots of lube spray. if it wont come off then spray loads of rust eater / lube stuff (wd40) leave it over night and have a go in the morning. it should then come off very light.
He who brakes Looses
To old to die young
2woody
  • Northumberland
Re: steering idler
« Reply #5 on: 06 March 2010, 22:42:18 »
do also remember to check the length of the new idler - there are different lengths available
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: steering idler
« Reply #6 on: 06 March 2010, 22:51:14 »
Exactly - this is the preferred method here!
