Author Topic: Excessive Cranking On My TD  (Read 3882 times)
Squealey
  • Donington, Lincs
« on: 10 March 2010, 20:41:15 »
Evening all
Thanks to Autoglass I wont have my car back on the road till not long before April, and to say im a bit pee'ed off is an understatement.
But it gives me a chance to look at another problem. i completed the headgasket only a couple of days ago but due to having no MOT have been unable to do more than a blast around the block, but there seems to be a small problem, it takes about 5 seconds of cranking before it will fire, longer if cold. It used to literally be half a second and go, not any more.
Anyone come across this before and found a solution, or anyone got any ideas on what could be wrong?
As ever, thank you.
Wayne
Re: Excessive Cranking On My TD
« Reply #1 on: 10 March 2010, 20:56:50 »
Check that there are no leaks from the injector link (spill) pipes :y :y
Squealey
  • Donington, Lincs
« Reply #2 on: 10 March 2010, 21:07:30 »
Are those the short rubber pipes that run between each injector?
« Reply #3 on: 10 March 2010, 21:11:14 »
yup. also bleed the pipes.  failing that, check glowplugs, but they aren't that old to be honest
hoofing it
« Reply #4 on: 10 March 2010, 21:25:19 »
have you knocked a wire(s) off the glowplug(s) when doing the h.g.
did it start ok before the h.g was changed.
Squealey
  • Donington, Lincs
« Reply #5 on: 10 March 2010, 21:46:51 »
yeah, it started fine before the h.g and it also started fine when it had the dodgy h.g on it for a couple of hours. All the glow plug wires look good and attached.
Its not like im worried it won't start, its just as though its self bleeding every time.
hoofing it
« Reply #6 on: 10 March 2010, 21:50:31 »
did you take the injectors out when the hg was done
Squealey
  • Donington, Lincs
« Reply #7 on: 10 March 2010, 22:37:45 »
No, not at all.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #8 on: 10 March 2010, 22:45:16 »
My first TD was just like that too.
And that was even after a brand new injection pump!
I never did fathom this out, and there were no codes stored either.
My latest TD is absolutely 'on the button' - always :y
Arrolman
  • Renfrew,Scotland
« Reply #9 on: 10 March 2010, 22:55:39 »
Hi,
I had this twice on my TD. First time was the spill pipe was split, second time was glowplugs knackered
Cheers,
Iain
Looking to win the lottery..........
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #10 on: 11 March 2010, 09:28:53 »
Lift pump in fuel tank
Ddraigcymro
  • South Wales
  • Hate the game not the player!
« Reply #11 on: 11 March 2010, 10:09:47 »
Have you tryed puting car in gear with handbrake off and rock a little, after doing this will it start a little easyer.
I don't suffer from insanity, I enjoy every minute of it.
Squealey
  • Donington, Lincs
« Reply #12 on: 11 March 2010, 12:34:41 »
Its an Auto :(
MickAP
  • South Derbyshire
« Reply #13 on: 11 March 2010, 14:58:48 »
What's the theory behind this one then, I mean how's that going to help? :-/
Mick ;)
Ddraigcymro
  • South Wales
« Reply #14 on: 11 March 2010, 15:03:35 »
Well it wasnt a fool proof plan but I have found that if I put mine in gear and releas the handbrake I feal as though it starts on the button more often, could just be my car and compresion down or somthing just thought it might be of use for sombody.
