Author Topic: DISPLAY ?  (Read 1622 times)
mikey.s
  • east calder
DISPLAY ?
« on: 12 March 2010, 19:17:17 »
Hiya guys while driving home tonight the display on my dash changed from 108 miles to F miles the fuel gauge went to empty then after about 5 minutes it came back up a bit but display dropped down to 80 miles any ideas ? :question
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: DISPLAY ?
« Reply #1 on: 12 March 2010, 19:22:23 »
might be a lose plug on the back of the display.
Re: DISPLAY ?
« Reply #2 on: 12 March 2010, 22:14:30 »
Utter 'dangle berries'
The key is the fuel gauge went to zero.  The display gets its fuel level reading from the instrument panel (try your mid with instrument panel out).
It could be the connector on the back of the instrument panel - press firmly on the rev counter with palm of hand, see if it seats better.  Failing that, check condition of connectors at tank end (inspection cover in boot)
Re: DISPLAY ?
« Reply #3 on: 12 March 2010, 22:53:01 »
 ;D ;D ;D ;D ;D Finally! Just one in a long line of 'dangle berries'..... >:(
Re: DISPLAY ?
« Reply #4 on: 12 March 2010, 22:58:15 »
Aw come on guys, rusty's answer was in essence the same as TB's, only worded different ::) ;D
Re: DISPLAY ?
« Reply #5 on: 12 March 2010, 22:59:18 »
And he means well :y
Re: DISPLAY ?
« Reply #6 on: 13 March 2010, 02:24:51 »
And he gives people incorrect advice  >:(
rustym95
Re: DISPLAY ?
« Reply #7 on: 13 March 2010, 04:06:13 »
when you brakedon on the side of the road good luck cos ill not stop for you, you give people a bad name, and your self.
Re: DISPLAY ?
« Reply #8 on: 13 March 2010, 15:05:51 »
not doubting your good intentions rusty, but if you see me broke down, please dont stop...unless its for a chat of course.
This situation has gone on for a while, and personaly i'm suprised it hasnt bought more attention. Sorry rusty, just is.
rustym95
Re: DISPLAY ?
« Reply #9 on: 13 March 2010, 15:39:06 »
every one gets it wrong from time to time we can only see what is said, i take my time and if i have wot they need i give it, i dont charge its nice just to help, i have lots of thanks from members on here, not every one talks mec, ive stoped car on road so they dont get a ticket, just some people just like to start stuff and not polite, if its wrong then its wrong but if its worng and it works whats that then.
Re: DISPLAY ?
« Reply #10 on: 13 March 2010, 16:07:28 »
usually, people take a little time to learn the approach, diagnosis on a pc is hard enough without having the issue in front of you hands on. Its all about communication, the original poster has to describe the issue correctly, we need to read it correctly, and give as accurate response as possible, it really doesnt help anyone when any old bodge reply that may or may not be relevent is thrown in to the mix, we all get it wrong from time to time, we get tired and miss read etc...but if the basic approach is "any old reply will do", which is how you come accross, then it degrades the forum integrity.
I'm getting a bit above my station here, its not my forum and not for me to start throwing my wait about, but i am entitled to an opinion, that being, dont post unless your certain of a corret outcome bassed on your experience, its other peoples money your messing with.
And if your guessing, say so, but probably best not to guess at all tbh.
« Last Edit: 13 March 2010, 16:10:36 by chrisgixer »
Re: DISPLAY ?
« Reply #11 on: 13 March 2010, 17:20:21 »
Accurately and nicely put mate  :y
This forum has a good reputation for accurate help and advice, which we should protect.
« Last Edit: 13 March 2010, 17:47:43 by dbug »
Abiton
Re: DISPLAY ?
« Reply #12 on: 13 March 2010, 17:32:04 »
Here's hoping I don't get accused of posting 'dangle berries', but I had a problem that gradually got worse with the fuel gauge dropping out.  Tried lots of fixes including boogering about inside the clocks, but eventually cracked it, as detailed my last post of this thread:
http://www.omegaowners.com/forum/YaBB.pl?num=1242500983/1#1
I posted a sketch of the gauge sender recently, to try to show what I was describing in words in that thread.  If you're good with searches you'll find it fairly easily.  :)
« Last Edit: 13 March 2010, 17:33:08 by Abiton »
Re: DISPLAY ?
« Reply #13 on: 13 March 2010, 17:49:18 »
Unlikely mate - you spent time diagnosing and fixing a problem - and then shared that success here :y
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: DISPLAY ?
« Reply #14 on: 13 March 2010, 19:02:21 »
Not the first time &  I don't expect the last time
"utter 'dangle berries'" is over the top especially from admin to another forum member.
I use the forum for help and give help where I can - not much I know
OTT in my opinion
Post count don't give a sh!t.
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
