Author Topic: auto query  (Read 1580 times)
no-idea
auto query
« on: 20 March 2010, 20:10:48 »
Hi
I have a 2001 2.2 auto - the car/spanner light comes up intermittantly. When its lit the car doesn't move/creep forward as normal and I have to really push down on the accelerator to get it to move. Car runs perfectly ok when the light is not showing. Can anyone give me an idea to the reason please?  :-?
Welung666
Re: auto query
« Reply #1 on: 20 March 2010, 20:13:19 »
Whatever is causing the EML (engine management light) to come on is dropping the gearbox into limp home mode. You need to get the codes read to find out the root cause. Where abouts are you? There are members all over the country with code readers :y
Re: auto query
« Reply #2 on: 20 March 2010, 20:16:53 »
Hi
Update your profile, then as Welung666 says, members near you may have a code reader & you can go from there :y Oh, Welcome to the OOF by the way ;D ;)
« Last Edit: 20 March 2010, 20:17:28 by philrich1064 »
johncol
Re: auto query
« Reply #3 on: 20 March 2010, 20:28:53 »
I would be interested in the result of the test also, I have been battling with my miggy's issue over the last few weeks - this being one as well. Im over in Ireland, have no idea where I might get access to a code reader.
  • Auckland
    • Mazda MPV
Re: auto query
« Reply #4 on: 20 March 2010, 21:19:34 »
Amazon?
« Last Edit: 20 March 2010, 21:20:26 by andyh »
Re: auto query
« Reply #5 on: 20 March 2010, 21:23:00 »
Search for "My Naff Code Reader" on e-gay :y
  • Auckland
    • Mazda MPV
Re: auto query
« Reply #6 on: 20 March 2010, 21:26:44 »
Tech2 £2,500
"My Naff Code Reader" £500
Maxscan £59
Re: auto query
« Reply #7 on: 21 March 2010, 16:38:31 »
..... When its lit the car doesn't move/creep forward as normal and I have to really push down on the accelerator to get it to move. ....
The car's setting off in 3rd, manually selct 1 & 2 as you would in  a manual.
Re: auto query
« Reply #8 on: 21 March 2010, 17:16:03 »
As a small "matter of interest" .. if in "limp mode"  you can select position 2 as much as you like .. but you won't ever get 2nd gear !!
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Page 138 column 3 .. :)
Re: auto query
« Reply #9 on: 21 March 2010, 17:26:52 »
That's not what my box did when I forgot my throttle position sensor. D would give 3rd, & manually I could select 1 & 2 I certainly couldn't get the car into 4th
The auto's use a 3 speed auto with an electrically operated 4 gear bolted to the side, ie it's not that dissimilar to the auto box found in an early 3 speed auto Senator A or Monza
Re: auto query
« Reply #10 on: 21 March 2010, 17:30:15 »
If you read that link .. you will see that when in limp mode, position 2 gives 3rd gear, position 3 gives 4th gear .. and position 4 stays in 4 ... so it will FEEL like you've changed gear .. but not to the one you think !!!
« Last Edit: 21 March 2010, 17:30:46 by entwood »
Re: auto query
« Reply #11 on: 21 March 2010, 17:57:26 »
I think I could tell whether I was in 3rd or 4th on a motorway Nige!  ;)  ;)
