Author Topic: Air con compressor questions  (Read 982 times)
lou
  • Romford
  • Always expect the unexpected
« on: 23 March 2010, 18:35:53 »
How hard is to change the compressor or what's involved (I know about the gas issues) mechanically. What would be the rate be. for a garage to change it and is it worth buying a second hand one of fleabay.
I suspect mine is leaking, had it regassed last week (very cold then) but a week on I am not so sure???
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Air con compressor questions
« Reply #1 on: 23 March 2010, 18:40:08 »
did the guy who did the re-gass use the dye in the system,if he did then go back and he will be able to see where your leak is with the lamp that they use.There are lots of places that the system can leak at besides the compressor
« Last Edit: 23 March 2010, 18:41:33 by henryd123 »
other rides
lou
  • Romford
« Reply #2 on: 23 March 2010, 18:53:42 »
No he did not, it just got low as it had not been done for at least 2 years and just put it back up to pressure.(a friend of a friend so to speak)did not charge me.
« Reply #3 on: 23 March 2010, 22:38:59 »
get an a/c pro involved - can use a sniffer to find leak.
Why do you think its compressor?  Could be a nš of items on the system that can leak.
Compressor not too hard to get off/refit - you need a helper and a few extensions to undo pipe from top of compressor - then we had to bar anti-rool bar to clear compressor to get it out and back in.  Usual reasons to swap compressor are clutch failure or bearing failure.
