Author Topic: crankshaft sensor removal 2ltr 16v no AIR con  (Read 865 times)
OGCDaz
  • ashford kent
« on: 28 March 2010, 22:21:59 »
How do i remove it not very gd with cars  :'( :'(
Error Code P0335 Crankshaft sensor error
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: crankshaft sensor removal 2ltr 16v no AIR con
« Reply #1 on: 28 March 2010, 22:27:44 »
Should be easy enough without the aircon pump there mate.
It is around where the dipstick goes into the block (on the passenger side) one bolt hold the Crank Sensor in place think its an E10 (torx socket) then just a matter of routing the cable in the same position and pulling it in  :y
OGCDaz
  • ashford kent
« Reply #2 on: 28 March 2010, 22:36:06 »
do i go underneath or above m8 ?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #3 on: 28 March 2010, 22:39:21 »
I personally would go from underneath to undo the torx bolt, then pull out the Crank Sensor. Then go from the top to pull it out and thread the new one whilst doing it so you know where it goes :y
Page created in 0.198 seconds with 16 queries.
