Author Topic: Auto box service.  (Read 2403 times)
MadMark73
  • Taunton. Somerset.
  • She is a bit of an animal!!!
    • 98 3.0 Elite Estate
Auto box service.
« on: 05 April 2010, 20:48:49 »
Hi all.
I have just got a 2nd hand ar35 autobox for my miggy(very kindly delivered yesterday by Ross(broomies Mate),as mine leaks.
What should I do to it before replacing mine, i.e. any seals that I should do as it is on the floor etc.
Cheers, MadMark73.
Re: Auto box service.
« Reply #1 on: 05 April 2010, 20:51:17 »
If its good, then nope.
You may need to do an atf change anfterwards...
MadMark73
« Reply #2 on: 05 April 2010, 20:52:56 »
Is it not worth doing incase they fail once on the car?
MadMark73
« Reply #3 on: 05 April 2010, 21:00:59 »
And also how easy wil it be to change as only got ramps and axle stands.
Can it be done that way or would it be easier to take engine and box out in one?
There will only be me doing it.
Unless someone would like some beer tokens for giving me a hand.
« Reply #4 on: 05 April 2010, 21:03:57 »
Ramps ok - ideally 2 people as box quite heavy - if not use trolley jack to lower/raise.
« Reply #5 on: 05 April 2010, 21:13:06 »
When I was in the same boat I took the decision to change the ATF and replace the thrust washer while it was off the car.
« Reply #6 on: 05 April 2010, 22:10:47 »
If you go to Opie oils website now they have extended their 30% discount so the fuchs gearbox oil is very cheap but I think it may end tonight
Sixstring
  • Lydney, Gloucestershire
« Reply #7 on: 06 April 2010, 11:42:07 »
BE CAREFUL!!!
gearbox is heavy, and if it comes off the spline it can break tibia and fibia bones in your shin easily....would recommend NOT doing it on your own, but if you must/have to use a plank under TWO trolley jacks to share the load, and you will also find with two you can tilt the box to engage it easier. (broke mine a few years ago doing just the same as you in my drive on my own)
Be safe.
Mike
« Reply #8 on: 06 April 2010, 14:04:24 »
.. and take the gearbox out and replace it with the torque converter fitted (i.e. unbolt the torque converter from the driveplate). Do not try to pull the gearbox off the torque converter nose in-situ as this can damage the bush and oil seal that it runs in.
I would check the condition of the torque converter nose (check for scoring) and also the seal and bush on the gearbox that this locates into before refitting.
Road Hog Mad
  • Cheshire
« Reply #9 on: 08 April 2010, 16:29:46 »
mine bangs down a gear very occasionally when in traffic/town, my auto box is sealed for life on the 3.0 mv6 x reg, but i do believe people service them?!
« Reply #10 on: 08 April 2010, 17:12:00 »
Yes, fluid and filter change every 60K or so is advisable. :y
Thrust washer failure is a favourite, and if bits of it are found in the sump when doing the above a DIY repair is feasible.
Road Hog Mad
  • Cheshire
« Reply #11 on: 08 April 2010, 17:46:45 »
just waiting for some offers if someone is close or I could bring it to them :D
