Author Topic: urgent one on a 2.2 petrol  (Read 2991 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 12 April 2010, 10:50:42 »
a mate of mine has a 2.2 petrol auto miggy with a factory fitted gas kit ( ex police car )  :y
every now and again, it throws up a bit of a fanny fit  ;D
driving along normally and then, just for a few seconds, it will start to run sh*t then clear its self and of it goes  :(
yesterday, we stuck it on his box of tricks  ( snap on pro ) and cleared a couple of codes
these are from memory
p 1700   canbus service ?
p 1550   throttle position ?
car drove normally for a few hours then he stopped
came back out a hour later and now the car refuses to start  >:( >:(
not had a chance to go and recover it yet
anybody come across this one ??
anybody got any serious ideas ???
Re: urgent one on a 2.2 petrol
« Reply #1 on: 12 April 2010, 10:52:56 »
sounds like it could be the old 2.2 cam sensor with no really relavent code issue.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 12 April 2010, 10:54:37 »
we know the trottle body and breathers could do with a clean
would that make any differance to the codes ?
« Reply #3 on: 12 April 2010, 11:05:15 »
Should get rid of TPS code. Car will still start eventually with failed cam sensor
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 12 April 2010, 11:05:48 »
we have one on a head off a 2 ltr ecotech ??   ( erzy's  old head )
is it the same one ??
might have to use it to get it home  :(
« Reply #5 on: 12 April 2010, 11:08:57 »
from the TC site...the 2.2 uses:
Camshaft sensors
2.2                                          90520850       £70.50       £63.56       £54.86
nowt on the 2.0, checking EPC....
« Reply #6 on: 12 April 2010, 11:10:18 »
apparently, although not listed for 2.0 omega, that is used on
X20XER
X20XEV
Y22XE
Z22XE
So you may be in luck  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 12 April 2010, 11:10:39 »
Camshaft sensors
cheers
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #8 on: 12 April 2010, 11:12:42 »
cheers  lads, tools out time then  ;D
at least its not raining ................ YET !!   ;D ;D ;D
« Reply #9 on: 12 April 2010, 11:13:22 »
hmmmm
/me delves further...
90458252, is listed as the X20XEV one, no longer stocked, replace with
24445139
so you may be out of luck sorry
may just be a different connector, may be more than that  :-/
« Last Edit: 12 April 2010, 11:13:55 by jimbob »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #10 on: 12 April 2010, 11:16:56 »
hmmmm
24445139
only one way to find out  :) :)
and there is a rather big raincloud out side  ;D ;D
thanks again  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 12 April 2010, 16:44:47 »
right, only code stored relates to the gearbox ecu selector ??  ( can't remember the number )  :-[
speaking to a lad who drove it last week, apparently he had trouble getting it to start but cured it by moving the gear selector up an down the gate a few times  :-/
so we are now looking at the selector switch ??
opinions please ??
« Reply #12 on: 12 April 2010, 17:04:57 »
Remove it, give it a clean and reset it http://www.omegaowners.com/forum/YaBB.pl?num=1267956397
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 12 April 2010, 17:13:21 »
cheers rob  :y
« Reply #14 on: 12 April 2010, 17:18:13 »
Cam sensor can cause 1700 code  :y
(search in here on cam and 1700, 1 per thread, since beginning, many many hits)
