Author Topic: Windscreen Wiper Judder  (Read 3429 times)
Luzy6
« on: 08 April 2010, 14:36:14 »
Can anybody advise me. I have a 3.2 V6 2001 Executive and over the winter my drivers side wiper started to judder. Does anyone know whats wrong with it before I start to pull it to bits.
PS. Its an Opel (lefty) I now live and work in Austria, oh and its been a cold winter.
Thanks
Re: Windscreen Wiper Judder
« Reply #1 on: 08 April 2010, 14:37:15 »
probably just wants a new wiper blade  :-/
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #2 on: 08 April 2010, 17:14:28 »
Try swaping the bldes over and see if the other side judders , if it does just get new blades and jobs done.
He who brakes Looses
To old to die young
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #3 on: 08 April 2010, 17:34:41 »
If you swap the blades you will have to make sure they are not going to catch before you switch them on as they are of unequal lengths. while you have the blades removed it might be an idea to switch them on and see if there is ant judder in the mechanism
« Reply #4 on: 08 April 2010, 17:38:31 »
Take the plunge & fit flat blades, you won't want to go back to the old type, believe me. :y
Richard A
  • Aldridge, West Midlands
« Reply #5 on: 08 April 2010, 17:52:18 »
Fit a new pair of GM blades, other makes are crap, I have tried them all, including 'flat blades' which are no good over 60mph, DO NOT SWAP, different lenghts.
regards
richard a
richard a
« Reply #6 on: 08 April 2010, 17:58:34 »
regards
richard a
In your opinion of course? ;) Mine perform silently and correctly up to and occassionally over the speed limit  ::) I can't of course comment on their performance at Autobahn speeds! ;D
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #7 on: 08 April 2010, 22:13:18 »
regards
richard a
Yep couldnt agree more .... tried big name flat blades .... good at low speed but not when going faster ... i went back to standard blades  :y
Luzy6
« Reply #8 on: 09 April 2010, 11:07:43 »
Thank you all. Most helpfull. I'll change the blade.
I always stick to the 130 speed limit :-? well sort of ;)
Cheers
Sixstring
  • Lydney, Gloucestershire
« Reply #9 on: 09 April 2010, 11:10:39 »
I hope that is 130 KMS...........LOL!
(130 MPH would be nice.......but my miggy wouldn't even get there...........)
Luzy6
« Reply #10 on: 12 April 2010, 11:28:41 »
OK guys, I changed the blades.... Still a judder on the drives side blade. I removed the arms and the scuttle and associated trim parts and seals. Examined the area for any obvious defects. Found a loose screw on one of the rods... No nut attached. I replaced the plastic screw nut thing and bolted it all back together. Refitted the arms.... still a judder on the drives blade.... >:( They work better but still a judder... any other ideas appart from falking out for a new expensive wiper motor?
Thanks
Luzy6
« Reply #11 on: 12 April 2010, 11:31:13 »
Oh and that is 130 kph. Whats that about 80 mph. Mine goes like stink. Had it up to 200 kph once but to much traffic and stupid bends. Should do 249 kph I think!  :y
« Reply #12 on: 12 April 2010, 11:33:08 »
not used polish or rainx or similar on your screen have you?
they can cause judder...
Luzy6
« Reply #13 on: 12 April 2010, 12:59:20 »
If it was because of polish or something else would it not effect both blades?
I dont use polish but it may get something on from the car wash. They dont like you to wash your cars at home in Austria. Something about contaminating the ground water with soapy diposites and oil. They prefer you to go to a car wash.
« Reply #14 on: 12 April 2010, 13:08:42 »
could be worth making sure the screen is really clean, good clean with methelated spirits or similar perhaps...
clutching at straws a bit, but if a blade judders, normally time for a new blade.
Screen contamination can also cause judder. So try and rule that out.
Honestly can't think of a 3rd thing to try...
but yes, would expect it to be both sides equally, unless your car wash put too much of something on that side of your screen  :-/
« Last Edit: 12 April 2010, 13:09:17 by jimbob »
Page created in 0.031 seconds with 16 queries.
