Pages: [1] 2 3  All   Go Down
Author Topic: V6 big end shells - how much work?  (Read 3912 times)
Martin_1962
« on: 19 April 2010, 07:51:11 »
This funny noise my car has, if it is as above, how much work to fix?
Thanks
Martin
Re: V6 big end shells - how much work?
« Reply #1 on: 19 April 2010, 07:57:49 »
Thanks
Martin
Mr Haynes suggests the conrods can be reomoved with the engine in situ ......  :-/  :-/  :-/  :-/ never done or seen it done though.  :-/
Martin_1962
« Reply #2 on: 19 April 2010, 08:02:10 »
AFIAC the conrods can stay if - if the shells can be changed - if the noise is bottom end that is
« Reply #3 on: 19 April 2010, 08:08:50 »
That's what I meant, if you can remove conrods, they have to unbolted so that'd mean shells could be changed.
What makes you think the bearings are shot?  :-/
« Reply #4 on: 19 April 2010, 08:30:24 »
Support engine from above, sumps off, baffle out, pickup off.....and away you go
« Reply #5 on: 19 April 2010, 08:31:33 »
You mean the main ally sump?
« Reply #6 on: 19 April 2010, 08:31:53 »
You were looking forward to doing that on mine - is that why you knew :P
Martin_1962
« Reply #7 on: 19 April 2010, 09:01:33 »
Aghhhh!
Quiet all the way to work.
Stuck in R and it started.
Parked up still going.
Lifted the bonnet and the mechanics over the road had a listen under bonnet.
That sounds fine - no knocking noise ::) ::) ::) ::)
« Reply #8 on: 19 April 2010, 09:57:34 »
Maybe it's a transmission issue?
« Reply #9 on: 19 April 2010, 10:02:12 »
If its a knocking in drive .. perhaps its the rubber bushes for the drive shaft allowing too much movement ??
« Reply #10 on: 19 April 2010, 10:05:27 »
Its not the iron vibrating on that ironing board someone has bolted to the boot is it?
« Reply #11 on: 19 April 2010, 10:16:06 »
Really doesn't sound like big ends to me if the noise is coming and going. Would expect big end noise to be based on load, and always there, or at least there once the oil is hot.
Worth checking the torque converter to driveplate bolts are tight, and all present?
« Reply #12 on: 19 April 2010, 10:17:00 »
Stop scaring me :o
Martin_1962
« Reply #13 on: 19 April 2010, 10:48:59 »
It is hot when noisy and not under the bonnet, almost like something was hitting the body.
Does it when stationary as well.
Might record it later
« Reply #14 on: 19 April 2010, 10:51:34 »
Is the engine moving at all ?? could be a worn engine mount ??
Loose exhaust bracket/hanger ??
Engines tend to "rock" more at idle than at higher RPM ... if something is slightly loose it could cause contact ?????
Pages: [1] 2 3  All   Go Up
