Pages: 1 [2] 3  All   Go Down
Author Topic: V6 big end shells - how much work?  (Read 3863 times)
Re: V6 big end shells - how much work?
« Reply #15 on: 19 April 2010, 10:54:22 »
Don't discount a knackered ancillary too. Does it do it with aux. belt removed?
Is the starter motor (and all other ancillaries) mounted securely and not working loose?
« Reply #16 on: 19 April 2010, 12:22:17 »
I have  recently changed the engine mounts and still I can feel the play with some lever (though not easy to position ) ..
check them..
2woody
  • Northumberland
« Reply #17 on: 19 April 2010, 17:45:28 »
getting back to the "exam question" - you also have to drop the front crossmember.
not actually all that difficult a job.
« Reply #18 on: 19 April 2010, 19:10:11 »
Why?
Subframe I can understand but, the front cross member?
brett wood
« Reply #19 on: 19 April 2010, 19:29:37 »
might sound daft but ive had a knocing noise on mine turns out its the end of the aircon pump worth a look
Martin_1962
« Reply #20 on: 19 April 2010, 20:58:48 »
I'm going to wait and see, if they need changing I am not sure what to do, as I go off on holiday before too long.
Martin_1962
« Reply #21 on: 19 April 2010, 21:00:52 »
Mine is idle only when been running for at least 15 minutes and cannot hear under bonnet
Martin_1962
« Reply #22 on: 19 April 2010, 21:21:54 »
I am going to just see what happens I might need a JV6 or DLK as I don't have long until I disappear, and I have to get the caravan sorted first.
It does sound really worrying though - I will record it tomorrow and upload.
Aux belt off engine needs to be hot and it is difficult to get the belt off with plenum on.
Martin_1962
« Reply #23 on: 19 April 2010, 21:40:09 »
Aircon pump would not be too bad.
At traffic lights it did it up to about 2000 rpm when engine noise meant I couldn't hear it.
Under load, no noise, road noise covers it as well.
It first happened after trying to work out why the 0305 was happening, I drove at 6500rpm in first for about 20 seconds with little load, would that have caused any issues?
« Reply #24 on: 20 April 2010, 09:25:21 »
I got TheBoy's aux belt off and back on again with plenum and multirams in place. :y
It must be worth a try just to eliminate the ancillaries, surely?
No problem with it being hot. You only have to run it for 30 seconds and not under load. It'd almost cool by convection.
« Reply #25 on: 20 April 2010, 09:31:26 »
I got TheBoy's aux belt off and back on again with plenum and multirams in place. :y .....
I recently managed to remove mine with everything in place. But had to admit defeat putting the new one on, I ended up with a cat's cradle of fan belt, & took the bag pipes off before I blew a gasket.  ;D
« Reply #26 on: 20 April 2010, 09:44:35 »
Admittedly it's easier if you're putting the same one back on.  ;D
« Reply #27 on: 20 April 2010, 09:48:40 »
Ah! That's easy  ;D. I thought you meant removing to replace the belt.   :y
2woody
  • Northumberland
« Reply #28 on: 20 April 2010, 11:53:31 »
Why?
we mean the same thing. The frame underneath that the engine mounts and the wishbones bolt to. The thing the Yanks call the K-member.
« Reply #29 on: 20 April 2010, 18:43:07 »
Piston slap due to overfuelling?
Pages: 1 [2] 3  All   Go Up
