Author Topic: tech 2 in kent  (Read 1759 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
tech 2 in kent
« on: 27 April 2010, 03:02:48 »
hi all does anyone in kent or nearby have a tech 2 ? thanks
2001 MV6 3.2 manual been converted from 2.6 auto
amba
  • Medway towns
    • German V6
Re: tech 2 in kent
« Reply #1 on: 27 April 2010, 07:50:50 »
Kevin Wood,is about the closest in the South.....what is the problem ?
bigtow
  • rochester kent
Re: tech 2 in kent
« Reply #2 on: 27 April 2010, 10:01:27 »
need to check why a airbag light is on
amba
  • Medway towns
    • German V6
Re: tech 2 in kent
« Reply #3 on: 27 April 2010, 10:29:07 »
Have you removed  steering wheel or front seats recentley or did the light just appear ?
As said Kevin is the closest Tech 11 geru,but you may find just a simple code reader will reset the light.
bigtow
  • rochester kent
Re: tech 2 in kent
« Reply #4 on: 27 April 2010, 10:48:25 »
only just brought car from
RobseyMV6 it was on when he had the car . it has had sports leather fitted instead of the standard elite leather
Re: tech 2 in kent
« Reply #5 on: 27 April 2010, 10:50:15 »
hmmm....are the side airbags present in your seats?  wonder if it had old seats fitted  :-/
If so I beleive the ECU can be reconfigured to not have side airbags...
amba
  • Medway towns
    • German V6
Re: tech 2 in kent
« Reply #6 on: 27 April 2010, 10:53:53 »
My elite has recaro leather fitted (as standard from new)and these have side air bags fitted...worth just looking to see if your front seats have side air bags,as if not ,as Jimbob suggests will need reconfig with Tech 11
bigtow
  • rochester kent
Re: tech 2 in kent
« Reply #7 on: 27 April 2010, 11:03:13 »
yes the new seats have side airbags . just wondering if the ingition was turned on while the seats were out ?
Re: tech 2 in kent
« Reply #8 on: 27 April 2010, 11:07:26 »
well sounds like you have the right stuff..
So any good reader should be able to say why it is on, and reset it if there is no problem present.
If the computer can also do live data, such as "My Naff Code Reader" / tech2 etc then it will enable fault finding.
bigtow
  • rochester kent
Re: tech 2 in kent
« Reply #9 on: 27 April 2010, 11:14:34 »
are the ones you can get off ebay that plug into your usb scocket of a laptop ?
Re: tech 2 in kent
« Reply #10 on: 27 April 2010, 11:37:58 »
yes, there are a variety one there.
A lot of them are illegal chinese clones...so no discussion on these please.
