Author Topic: Towing - auto gearbox question  (Read 2231 times)
I_want_an_Omega
« on: 29 April 2010, 08:05:14 »
I know its agreed that you should disconnect the propshaft prior to towing a car with auto transmision - but but could someone please advise me exactly how to do that please.
Thanks ........... Rob
Re: Towing - auto gearbox question
« Reply #1 on: 29 April 2010, 08:18:08 »
3 x M12 nut & bolts at either end of the prop shaft. When the car is up in the air, you might want to allow for being able to turn a back wheel to get at all bolts. Sod's law will say that one of them will be right at the top where you can't get to it.  :y
I_want_an_Omega
« Reply #2 on: 29 April 2010, 08:31:44 »
Thanks - so I'm basically going to take the prop shaft off completely ....  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 29 April 2010, 08:37:02 »
No. Drop it at the diff :y
« Reply #4 on: 29 April 2010, 08:46:29 »
But ......by the time you've tied the free end of the prop up, you could've undone the other 3 bolts & not have to worry if the prop will break free & fall to the ground enroute  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 29 April 2010, 08:50:11 »
It won't fall to much holding it up :y
Plus it won't turn only the diff will and it wont be connected to the prop ;) ;)
« Reply #6 on: 29 April 2010, 08:54:36 »
That's why it's being disconnected  ;)  ;)
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
« Reply #7 on: 29 April 2010, 08:56:51 »
Is it worth suggesting that flanges are marked, especially if the prop-shaft is completely removed. Then refitting in the same postion will reduce the risk of out-of-balance vibrations
spin
  • Preston Lancashire
« Reply #8 on: 29 April 2010, 10:40:37 »
I recently had to tow my 2.0 litre omega auto and was advised  by auto gearbox specialist that i could tow my car at a maximum speed of 20 mph for a distance of no more than five miles without disconnecting the prop, we followed these instructions and the gearbox was fine.
« Reply #9 on: 29 April 2010, 10:42:58 »
Vauxhall Book says 50mph for 60 miles  :y
« Reply #10 on: 29 April 2010, 10:47:19 »
Well ..... they're nearly the same  ::)  ;D  ;D  ;D
russ b
  • dudley west midlands
« Reply #11 on: 29 April 2010, 10:49:55 »
please excuse me for sounding dumb, could someone tell me why you have disconnect prop for towing. but what really confuses me is that is- isn't the prop what powers the drive. if thats disconnected whats powering the back wheels. sorry for being ignorant but if you don't ask you never find out..
« Reply #12 on: 29 April 2010, 10:55:06 »
this is for being towed, not towing to be more precise  :y
the wheels spinning madly, driving gearbox when being towed kills the auto gearbox, so disconnect the prop, then the gearbox isnt being driven  :y
« Reply #13 on: 29 April 2010, 10:56:18 »
Yes, the prop does power the back wheels but via the gearbox via the engine. If your engine isn't running, you're not powering the back wheels  ;)
In normal running, your geabox is turned by the engine, which drives a lub pump inside the autobox to lubricate it. If you're towing it, the gearbox doesn't get lub'd ..... resulting in a dead g/box.
What's powering the back wheels of the towed car? .... The tow car up front  :y  :y
« Reply #14 on: 29 April 2010, 10:57:19 »
Ah! I now understand the confusion ....  ;)
