Author Topic: 15/40 Oil  (Read 1645 times)
15/40 Oil
« on: 30 April 2010, 18:38:36 »
Been given a bottle of 15/40 by mistake from my local dealer on 4 for 3 offer, funny that cause at the time she said the system would only let her sell 3, but we had 4...
Not till i got home and realised it  :(
Can i use 15/40 in my 2.2? Or is it worth going back for 10/40  :-/
Re: 15/40 Oil
« Reply #1 on: 30 April 2010, 18:43:34 »
yep.. anyway its not winter now..
Re: 15/40 Oil
« Reply #2 on: 30 April 2010, 18:45:43 »
Was it 3 pence a gallon cheaper than the 10/40 Tunnie ;D
Re: 15/40 Oil
« Reply #3 on: 30 April 2010, 18:46:31 »
thats mineral not semi....
Re: 15/40 Oil
« Reply #4 on: 30 April 2010, 18:47:52 »
book says...
We recommend using Vauxhall engine oils
with the following grades and viscosities:
ACEA A3/B3 SAE 0W-30
– or –
ACEA A3/B3 SAE 5W-40
– or –
ACEA A3/B3 SAE 10W-40
The range of application of the oil is
dependent on the outside temperature,
see d iagram on following page.
When using commercially available engine
oils, as a matter of principle only those oils
that meet the minimum quality
requirements specified in the following
table are permissible.
Engines State-of-the-art oils
Petrol ACEA- A3
ACEA- A3 /B3
ACEA- A3 /B3 /B4
Diesel ACEA- B3
ACEA- A3 /B3
ACEA- A3 /B3 /B4
Only the following viscosity classes are
permitted:
SAE 10 W-30 (or higher than 30) or
SAE 5 W-30 (or higher than 30) or
SAE 0 W-30 (or higher than 30).
The range of app lication of the oil is
see diagram on following page.
Engine oils which are specifica lly
designated for use in d iesel engines a re not
suitable for petrol engines.
If the engine oil specified here is not
available in your country, consult your
Service Booklet.
you have
Engine Oil - Mineral 15W40 SL/CF A3/B4
« Last Edit: 30 April 2010, 18:50:06 by jimbob »
Re: 15/40 Oil
« Reply #5 on: 30 April 2010, 18:48:48 »
Nah, i did ask for 4 x 5L of 10/40!
So thats a no then, take it back?
Re: 15/40 Oil
« Reply #6 on: 30 April 2010, 18:49:45 »
..... take it back?
Yep!  ;)
Re: 15/40 Oil
« Reply #7 on: 30 April 2010, 18:50:31 »
You could always cook your chips in it ::)
Re: 15/40 Oil
« Reply #8 on: 30 April 2010, 18:52:25 »
..... take it back?
Yep!  ;)
Cheers  :y
No sure if i fancy it on my chips  ;D
Re: 15/40 Oil
« Reply #9 on: 30 April 2010, 18:53:58 »
these oils are not that different..  I can use them anyday, much better than a dirty oil anyway.. ;D
Re: 15/40 Oil
« Reply #10 on: 30 April 2010, 18:57:47 »
.... much better than a dirty oil anyway.. ;D
I have to agree with you there Cem.
Anything is better than nothing, or where I live you'd say .... owt's better than nowt  ;)  ;)
Re: 15/40 Oil
« Reply #11 on: 30 April 2010, 19:00:32 »
rereading my post....
Your oil is not on the recommended list, but is on the permissible list....
So doesnt sound like its gonna do any harm...
Re: 15/40 Oil
« Reply #12 on: 30 April 2010, 19:03:37 »
Was completely out if oil when i went up, i like to keep a healthy stock so will pop up for another 4 next week, think i will get it swapped then  :)
Re: 15/40 Oil
« Reply #13 on: 30 April 2010, 19:04:09 »
looking on services oil change intervals (which some  friends follow like a holy book even though I warned them many times) 15-20K kms   on brand new cars  :-?  ,  I can say thats mud not oil ..
now apparently a clean 15-40 will do the job but will be slightly thicker on startup ..
Re: 15/40 Oil
« Reply #14 on: 30 April 2010, 20:26:19 »
He He, sounds like me first thing in the morning! ::) ;)
Page created in 0.053 seconds with 16 queries.
