Author Topic: Noisey V6 engine  (Read 2652 times)
BgBLizard
  • Yeovil
    • 3.0 MV6
Noisey V6 engine
« on: 11 April 2010, 08:53:11 »
Hi All
Just wondering if anyone could help? I have a 1999 3.0 MV6 which has just started making a noise from the engine. This noise is present at start up and when warm but only up to 3000 rpm and is accompanied with vibration. There is also a lack of performance as well.
The noise is low in pitch, almost a knockand  it does not get any worse under heavy load. It is more noticeable from inside the car more than under the bonnet but I cannot pinpoint exactly where it is coming from.
So far I have changed the oil and checked the timing belt just to see if it had slipped a tooth but all was fine. I have checked all the alternator aircon and steering pump bearings all that was apparent was a little end play in the water pump.
It would be much appreciated if any one could help, even if it is just to eliminate certain factors.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: Noisey V6 engine
« Reply #1 on: 11 April 2010, 11:08:36 »
Hello,If you feel you need to totaly clear all auxillarys, just warm up engine slightly, then remove auxillary belt. Could be your tensioner. Hope you find it I know the feeling very well  :y :y
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #2 on: 11 April 2010, 11:19:59 »
Thanks for that Cliffo
Will try that tonight after work.
I am concerned that it it is something more serious but have little experiance more major engine problems so do not know what they sound like.
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #3 on: 11 April 2010, 12:54:56 »
hydraulic lifters ?
v6 cam locking kit  member:y
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #4 on: 11 April 2010, 13:10:04 »
Thanks Mark
Anyone tell me the best way to check this and what do I look for. I have fitted vectra rocker covers on it so haven't got any issues with poping them off.
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #5 on: 11 April 2010, 13:41:00 »
you can get lifter treatment from you local factor for about £7 . You just ad it to the oil job done :y
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #6 on: 12 April 2010, 10:33:59 »
Thanks I will try that but I did use Wynns engine flush when I changed the oil.
Also if there is anything else I can check before I dump the timming belt covers and plenum back on.
Thanks in advance, all your help is appreciated especialy as the Misses is making noises about changing cars >:( do wynns have something for that :)
sparkyw666.
  • aberdeen uk
  • aka mark w
« Reply #7 on: 12 April 2010, 14:31:56 »
engine flush is never a good idea in the v6 . It gets stuck in the oil cooler and thins your new oil . Try giving it another oil change followed by Wynns lifter treatment that should sort it out for you :y :y
« Last Edit: 12 April 2010, 14:34:17 by sparkyw666 »
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #8 on: 19 April 2010, 20:06:18 »
Hi All
Thank's all for your suggestions I have now added the Wynns lifter treatment and run it for a week, this appears not have not improved the problem even a little bit, just less tappity in the mornings.
Also dropped off the auxilary belt and no luck there either.
Had a chat with a guy at work and he had a listen, now after interigation (of me not the car) he extracted that I had used injector cleaner a couple days before this started ::) so his theory is that I blocked an injector. He has ruled out plugs leads  and dis pack for reasons to long to mention. My question is if anyone can help, how do I test which one I have blocked and is there any possibility of repair/unblocking.
Thanks in advance.
Welung666
« Reply #9 on: 19 April 2010, 20:33:10 »
Where are you? Maybe someone close by can have a listen?
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #10 on: 19 April 2010, 20:46:38 »
Yeovil Somerset
Car drives ok just a bit sluggish so I could travel.
Also possibly down at Bournemouth on Thursday.
Welung666
« Reply #11 on: 19 April 2010, 20:54:27 »
Yeovil Somerset
From me.... miles away and even further away ;D ;D Sorry  :(
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #12 on: 23 April 2010, 19:52:35 »
Hi
It has been confirmed that the problem is a misfire but not what is causing it.
Didn't think to do the paper clip test originally as there was no engine light on but it appears that I do have fault 19 RPM incorrect crank sensor. Could this be the cause of my trouble or just an old code in the memory.
Thanks in advance
« Reply #13 on: 23 April 2010, 20:03:22 »
It really wont help....and can cuase random running to so needs eliminating
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #14 on: 23 April 2010, 20:48:05 »
Thanks Mark
Just thought to add this missfire is not as bad as losing one pot all together, it is like it's running on 5 1/2 if you pull the leads off one by one it dose not seem to make much differance hope this helps
