Author Topic: oil in plug well  (Read 2414 times)
macca
  • bexhill-on-sea
oil in plug well
« on: 03 May 2010, 13:02:24 »
Hi,
While investigating the source of a coolant leak from the back of the engine area, i pulled the front HT lead off to find it covered in oil(3.0 mini facelift). Does this indicate a cam cover gasket failure? or something else?
thanks
mark
Re: oil in plug well
« Reply #1 on: 03 May 2010, 13:16:16 »
Hi,
thanks
mark
yes.  :(
I've just done the very same thing. Just about finished my cam belt from Saturday ... we were out all day yesterday - Honest!  :y and thought I'd pull no 1 plug lead to have a look   :'( Wet through with oil. So was no 3 but not as much  :'(
hey ho!  :-? :-?
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #2 on: 03 May 2010, 14:09:47 »
Oil in plug wells is a sign of rocker gasket.
an easy way to get the oil out of the plug wells is to use a syringe, the type for refilling your ink cartrige on the printer are good.
you will need to put a straw on the front ie from a wd40 can fits great,  its an easy way to get the oil out and saves a bit of money.
He who brakes Looses
To old to die young
OmegaGav
  • Hemel Hempstead
  • For god sake doooo something !!!!!
    • 08' Vectra 3.0 V6 Cdti
« Reply #3 on: 03 May 2010, 16:19:54 »
I used rolled kitchen roll  :y :y ;)
Yes it's my M&S goulash cannon. Ready Aim Fire...!!!
OmegaGav
  • Hemel Hempstead
« Reply #4 on: 03 May 2010, 16:26:49 »
Hi,
thanks
mark
Think you found 2 of the most common problems on the omega  :-[
1 the starship enterprise failure (HBV) ::)
2 cam cover gasket failure :-[
but you're in the right place, check maintence guides :y
« Last Edit: 03 May 2010, 16:27:22 by OmegaGav »
Kev_B
  • Leigh, Lancs
« Reply #5 on: 03 May 2010, 16:35:30 »
I used a Cif trigger-spray thing, put the tube right down into the well, and squirted it into a Pot Noodle tub...   :)   After eating the Pot Noodle of course...   ::)
OmegaGav
  • Hemel Hempstead
« Reply #6 on: 03 May 2010, 17:07:22 »
I hope it was beef & tomato, with heinz ketchup. not that awful sachet stuff  ;D ;D ;D
Smooth
  • N.Ireland
« Reply #7 on: 03 May 2010, 20:26:09 »
Small shryinge does the trick then use vx rocker gaskets :y
If Jesus had a licence he would drive an MV6
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
« Reply #8 on: 03 May 2010, 22:51:41 »
We used Elite Pete, completely hassle free.   ;D ;D
des
  • stoke-on-trent
« Reply #9 on: 04 May 2010, 10:47:25 »
Take it vx gasket means gen one.s
just done mine (none gen) still leaking :(
Bugger  >:(
« Reply #10 on: 04 May 2010, 10:54:33 »
Bugger  >:(
Yup Geniune Vx gaskets only, black sealant, and torque covers to 8Nm and will last a long time!
Pattern ones are rubbish
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11 on: 04 May 2010, 11:42:18 »
and probably be good to clean the breathers at the same time :y
other rides
ScaniaV8
  • Luton, Bedfordshire
« Reply #12 on: 04 May 2010, 14:13:01 »
As Henry suggests...it would be good to clean the breathers as well otherwise it's just false economy and likely to be blowing the gaskets again with resultant oil leakage.
