Pages: 1 2 [3]  All   Go Down
Author Topic: Exhaust Manifold Gasket  (Read 4981 times)
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
Re: Exhaust Manifold Gasket
« Reply #30 on: 05 May 2010, 19:03:05 »
Will do & thanks again  :y
If this works i'll leave u a little something in my will  ;)
tidla
  • solihull
« Reply #31 on: 05 May 2010, 19:12:27 »
in the old days carbs and stuff a misfire could be caused due to a weak mixture.
i know with closed loop system its supposed to self regulating..
if excess air is getting in from other than measured sources..
the lambda sensor is registering a rich mix and turning things down..
might by worth checking the exhaust readings.. :-?
tidla
  • solihull
« Reply #32 on: 05 May 2010, 19:29:26 »
just re read your topic..
1. is the cam covers still leaking?
2.the plenum chamber and associated pipework needs to be checked for splits disconections/ air leaks.
3. no codes.. concentrate on mechanical items.
4 checking/inspecting is cheap. :)
5 .egr valve sticking allowing dirty air in.
6.idle valve sticking slightly open.
« Last Edit: 05 May 2010, 19:58:48 by tapper888 »
Pages: 1 2 [3]  All   Go Up
