Pages: [1] 2 3  All   Go Down
Author Topic: Sluggish - what to check next  (Read 4565 times)
Martin_1962
« on: 01 May 2010, 11:48:51 »
New MAF (Bosch), new coil pack, tried full revs and it is not as quick as it should be.
Still have 0300 0305 stored.
Air filter is fine, cam timing was fine when last checked.
Petrol filter is new.
Just not as quick as it has been on full throttle full revs as it has been.
Thanks
Martin
« Last Edit: 01 May 2010, 11:49:21 by Martin_1962 »
Martin_1962
Re: Sluggish - what to check next
« Reply #1 on: 01 May 2010, 12:28:27 »
No error lights
0300
0305
0130
0173
stored
Welung666
« Reply #2 on: 01 May 2010, 12:32:37 »
No error lights
0300
0305
0130
0173
stored
Are they showing as present or not present?
EDIT: Odd that it's showing a lambda problem Bank 1 sensor 1 and a fuel trim for bank 2!
« Last Edit: 01 May 2010, 12:34:01 by Welung666 »
Martin_1962
« Reply #3 on: 01 May 2010, 13:04:51 »
No error lights
0300
0305
0130
0173
stored
I held the pedals down, no lights lit and I counted these.
How much work to swap out both Lambdas?
Tempted to get a DLK to do it.
Martin_1962
« Reply #4 on: 01 May 2010, 13:06:56 »
When Kevin wiped the codes it went like nobodies business, at the time it said slow Lamdba bank 1 on Tech 2
« Reply #5 on: 01 May 2010, 13:07:07 »
hmmm, if mixed bank errors, I wonder if you could have mixed up a connector somewhere...
Welung666
« Reply #6 on: 01 May 2010, 13:08:11 »
I can change your lambdas, I'm only up the road. I can get the "My Naff Code Reader" on to clear the codes and recheck them too :y
Welung666
« Reply #7 on: 01 May 2010, 13:09:01 »
 Possible as the bank 1 and 2 sensor 2's plug in next to each other.
« Last Edit: 01 May 2010, 13:09:28 by Welung666 »
Martin_1962
« Reply #8 on: 01 May 2010, 13:13:18 »
Never ben unplugged AFAIK
However perhaps both are on their way out.
As to car work - I have a great big white box in the way of my garage. :-[ :-[
So where do you live Welung?
Welung666
« Reply #9 on: 01 May 2010, 13:14:40 »
Dudley/Stourbridge borders.
« Reply #10 on: 01 May 2010, 13:14:45 »
didnt you drop them when you did you head work?
Martin_1962
« Reply #11 on: 01 May 2010, 13:35:06 »
No, and I can't even get a spanner on them.
Can't get car in working spot as the caravan is in the way.
Martin_1962
« Reply #12 on: 01 May 2010, 13:36:26 »
Oh Merry Hell area ;D ;D ;D ;D
Welung666
« Reply #13 on: 01 May 2010, 13:50:11 »
Yep, and hell it truly is! I live one side and work the other so I drive through it 4 times a day! No wonder I'm a bit  :D
Martin_1962
« Reply #14 on: 01 May 2010, 15:16:35 »
Just found genuine for 29.99 each
Pages: [1] 2 3  All   Go Up
Page created in 0.04 seconds with 14 queries.
