Author Topic: Misfiring/stuttering/running rough - no change!!!!  (Read 3159 times)
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« on: 10 May 2010, 10:46:54 »
The EGR was unscrewed & i've blanked it off, re-plugged it & its still running rough/stuttering/misfiring!
Could the egr valve be knackered & how would i know?
All the brand new ht leads are on the dis pack in the correct order & fully attached.
i've also pointed out that when the new plugs were taken off individually there were only 2 that made the revs dramatically change whilst the others hardly made a difference when taken off - what could this point to   :-/
PLEASE HELP    :'( :'( :'(
Re: Misfiring/stuttering/running rough - no change!!!!
« Reply #1 on: 10 May 2010, 11:36:26 »
RIGHT, that has proved its NOT the EGR then.
So go back to looking for other air leaks ;)
« Reply #2 on: 10 May 2010, 11:38:15 »
Is it better at higher revs?
eliteomegaman
« Reply #3 on: 10 May 2010, 15:04:22 »
It's ok on tick over but when driven it struggles through the gears & have only managed to get it up to about 2800rpm but not taken it higher cos of speed limit on road  ::)
Pipes have been checked for air leaks but nothing found  :(
If the breather pipes are cleaned do u think that might eliminate the problem?
This is really doing my head in  >:(
eliteomegaman
« Reply #4 on: 10 May 2010, 15:18:52 »
Forgot to mention (might be nothing?) when the engine starts from cold there's a whinning noise which disappears after a minute or so  :-?
John Lewis
  • Macclesfield, Cheshire
  • Macc is wack
« Reply #5 on: 10 May 2010, 19:31:59 »
Would like to know what this is too, that new Elite I got does the exact same thing.
« Reply #6 on: 10 May 2010, 19:40:11 »
seconday air injection pump fubar'd. It lives under the passenger side front wing and is there to appease the green brigade. Ignore it or unplug it and then ignore it  :y  :y
« Reply #7 on: 10 May 2010, 19:40:57 »
sai pump has knackered bearings. unplug it, problem solved.
« Reply #8 on: 10 May 2010, 19:41:57 »
It'd be childish to say I beat ya here too!  ::)  ::)  ;)
« Reply #9 on: 10 May 2010, 19:42:29 »
Anyone near you with Tech2 or equivilent, who can do some injector cutoff tests?
« Reply #10 on: 10 May 2010, 19:43:09 »
Child :P
« Reply #11 on: 10 May 2010, 19:44:38 »
Child :P
 8-)  8-)  8-)  8-) :P
eliteomegaman
« Reply #12 on: 10 May 2010, 20:09:34 »
Any thoughts on this please  :-?
And you lot STOP being childish otherwise i wont play with u!!  :D :D
John Lewis
  • Macc is wack
« Reply #13 on: 10 May 2010, 20:30:09 »
Ha ha. Nice, cheers!! Now, back to the case in point - misfire!  ;D
[size=8]/watches patiently[/size]
« Reply #14 on: 10 May 2010, 20:41:23 »
Faulty Lambda? :-/
