Author Topic: Rear brake pads 2.6 ....51 plate.  (Read 1695 times)
« on: 13 May 2010, 18:46:53 »
Can anyone please tell me how much I should pay for rear brake pads for my 2.6?.....Are they easy to fit?. . :y :y...and where is the best place to buy?.
.....Kwik fit want £60... :o :o
Thanks. :y
Re: Rear brake pads 2.6 ....51 plate.
« Reply #1 on: 13 May 2010, 18:48:02 »
they cost around £11 from Vx dealer!
« Reply #2 on: 13 May 2010, 18:56:06 »
As cheap as that for genuine parts.. :y. Is it an easy job?
« Reply #3 on: 13 May 2010, 19:03:08 »
All models disc pads                                       93169001        £20.75        £18.68        £12.23
retail ,trade, tradeclub, all plus the vat.
You will prob need a new spring as well, and maybe pins, these are just a few quid in halfords.
http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
shows how to, (plus the handbrake your not interested in)
iirc its basically
Wheel off,
push the pins through,
get the pads out
open bleed nipple, and force calipers open, close nipple
put in new pads
put in anti rattle spring and pins
I would probably now bleed the brakes too while I am there
Wheel back on.
« Reply #4 on: 13 May 2010, 19:42:58 »
Thanks Jimbob. I have a single trolley jack....what is the best (safest) place to put it on the underside of the car?.
« Reply #5 on: 13 May 2010, 19:49:22 »
around the bolt for the subframe bush works well...
hope you have an axle stand too....or put something (like the wheel yovue taken off) under the car to prevent a crushing fall.
« Reply #6 on: 13 May 2010, 19:52:39 »
 Yep thanks ....that's what I thought......but wanted to be sure. :y :y :y
MickAP
  • South Derbyshire
« Reply #8 on: 13 May 2010, 20:04:45 »
All you need here
http://cgi.ebay.co.uk/Vauxhall-Omega-Rear-Brake-Pads-pins-springs-G-M-Part-/220593550271?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item335c6673bf
I have some, not fitted yet ;)
Mick ;)
 Thanks Mick.... pads are right down to the last m/m......but no warning light for "low brake pads"...is showing.....does it only work for the front pads?.
« Reply #9 on: 13 May 2010, 20:07:38 »
yup, only alert at the front  :y
« Reply #10 on: 13 May 2010, 20:33:39 »
All you need here
Mick ;)
As thin as mine were?  ::) ::)
« Reply #11 on: 13 May 2010, 21:07:41 »
Ive had thinner  :-[  ;D ;D ;D
« Reply #12 on: 13 May 2010, 21:26:46 »
Rizzla type  ;)  :y  :y
tidla
  • solihull
« Reply #13 on: 13 May 2010, 21:55:32 »
.....Kwik fit want £600... :o :o
Thanks. :y
more like by the time they have finished :o
Page created in 0.04 seconds with 16 queries.
