Pages: 1 ... 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 ... 42   Go Down
Author Topic: Engine noise, terminal?  (Read 117714 times)
Matchless
  • Nottingham
    • A white van
Re: Engine noise, terminal?
« Reply #375 on: 30 March 2010, 15:54:32 »
I am going to put it all back together tonight and go for a start-up.....then some T2 tests.
Mark, if you want an excuse to delay this another day or two then I'm in need of a strong pair of hands on some 4m worktops.
« Reply #376 on: 30 March 2010, 20:51:12 »
Dow, you should have called me.
Hmmmm......well, what can I say....
« Reply #377 on: 30 March 2010, 20:52:07 »
Still dead?
« Reply #378 on: 30 March 2010, 20:53:10 »
Who knows, still puting it back together and its F cold!
About another hour yet to complete assembly and then test....
« Reply #379 on: 30 March 2010, 20:57:41 »
right radio silence for an hour please.
let him get on with it. ;D
« Reply #380 on: 30 March 2010, 21:01:09 »
if you catch cold, who is gonna repair that car.. go home ;D :y
« Reply #381 on: 30 March 2010, 21:25:59 »
Its back together and running.
No fault codes
No exhaust tick
A light tap noise can be heard, I have heard worse though
Injector cutoff test done......all cylinders firing, tap noise does not change in volume.....this effectively rules out the bottom end as the lack of firing on a cylinder would reduce the load on little and big end bearings hence the noice generaly stops or at least significantly quietens down under this test.
Now, I did notice a slightyly weak follower on No 1 cylinder inlet valve no 2.....
So.....2 choices.....get it stinking hot and see if it quietens down or (and the prefered choice), swap the followers on No1 bank.
« Last Edit: 30 March 2010, 21:28:23 by Mark »
« Reply #382 on: 30 March 2010, 21:29:09 »
No fault codes
No exhaust tick
Now, I did notice a slightyly weak follower on No 1 clinder inlet valve no 2.....
do you feel better/worse/indifferent to the noise before (granted you only heard on phone) ?
« Reply #383 on: 30 March 2010, 21:30:07 »
Sounds like you've virtually fixed it ...   :y :y :y :y
Nice one  ;) ;) ;) ;)
« Reply #384 on: 30 March 2010, 21:30:33 »
No fault codes
No exhaust tick
Difficult to tell given I only heard a recording and over the phone.
To me, its not bad.....but, could be better.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #385 on: 30 March 2010, 21:32:10 »
I have some Lifters if some are needed :y in fact a whole bank as the other bank are for someone else :y
« Last Edit: 30 March 2010, 21:33:02 by Loo-knee »
« Reply #386 on: 30 March 2010, 21:35:05 »
No fault codes
No exhaust tick
I thought it sounded bad enough I didn't want to drive it  :-/
« Reply #387 on: 30 March 2010, 21:38:28 »
I know it hasn't run for more than 5mins in last month, but would like to think oil is good/fresh enough that it should circulate well? Or have I misunderstood?
« Reply #388 on: 30 March 2010, 21:43:15 »
Deal done on a set of known good lifters.
Oil should be fine....it will only take 3 hours or so to fit them and jobs a good un
« Reply #389 on: 30 March 2010, 21:46:29 »
:D :D :D
Not sure I understand why letting it roast would/could quieten down more than running for a few mins (surely after a few mins, the oil should have pumped up lifters (as I assume that lifters aren't clogged with old oil, given the oil service strategy))?
Pages: 1 ... 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 ... 42   Go Up
