Pages: 1 ... 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 ... 42   Go Down
Author Topic: Engine noise, terminal?  (Read 117699 times)
0 Members and 3 Guests are viewing this topic.
Re: Engine noise, terminal?
« Reply #435 on: 04 April 2010, 21:46:49 »
« Reply #436 on: 04 April 2010, 21:47:53 »
Could that be a weak valve spring, or is defo lifter?  Just thinking out aloud really.
Which cylinder is it?
« Reply #437 on: 04 April 2010, 21:48:25 »
I have seen the same whereby it's a lifter..
« Reply #438 on: 04 April 2010, 21:49:27 »
On the upside, looks clean enough at the top end :D
« Reply #439 on: 04 April 2010, 21:53:25 »
And I'm sure the spring will get checked when the lifter is removed, just in case :y :y
less
  • Hemel Hempstead
    • 2.6 auto saloon
« Reply #440 on: 04 April 2010, 21:58:23 »
So..... does this mean the Silver Bullet is resurrected in the nick of time?  :)
Is the Golden Nugget just copying the Silver Bullet, with a bit of attention seeking behaviour?  :-?
Let's hope so. TB is due a little good fortune for a change  :y
« Reply #441 on: 04 April 2010, 22:03:16 »
Intrigued I am ....   why would taking the inlet manifold off and fitting the lpg stuff suddenly cause a lifter to malfunction ??? I can see no link between THAT work and THIS problem ....  and I don't believe in coincidences of this magnitude ....
« Reply #442 on: 04 April 2010, 22:03:20 »
I was thinking from a goldie point of view, not doubting Mr DTM's abilities ;D
« Reply #443 on: 04 April 2010, 22:04:40 »
I think we are in the realms of coincedence here.  And a further coincidence being the Golden Nugget appears to have developed exactly the same issue, that engine hasn't been touched at all :o :o :o
« Reply #444 on: 04 April 2010, 22:06:04 »
The common element is the angry object between seat and steering wheel  ::)
« Reply #445 on: 04 April 2010, 22:17:52 »
Yep...valve spring all fine.....the lifter is goosed......and saved for prosperity.
Cams back in, cam caps fitted, cam cover back on and cam sprockets back on.
Might get chance to finish the rest tomorrow evening.
I also dont beleave in coincidences......hence why a very methodical approach has been used.....
The weak lifter is on no 1 cylinder....inlet.
« Reply #446 on: 04 April 2010, 22:23:46 »
Coincidences do, rarely, happen... I think this may be proof of that.
It is strange though :-/ :-/
Sounds like the Golden Nugget problem may be similar, although we did discuss the fat is sounds like it's running on 5 and smells a bit "Unburnt Fuel" like too so possibly a lead problem too.
It's definitely like Diesel Knock.
« Last Edit: 04 April 2010, 22:24:16 by Lazydocker »
« Reply #447 on: 04 April 2010, 22:33:13 »
 ;D
2/2 no miss ;D :y
« Reply #448 on: 04 April 2010, 22:49:32 »
Oooo....your a bit close to 10K posts to be making statements like that cem  ;D ;D ;D
« Reply #449 on: 04 April 2010, 22:51:32 »
You read my mind, mr dtm ::)
Pages: 1 ... 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 ... 42   Go Up
