Pages: 1 ... 30 31 32 33 34 35 36 [37] 38 39 40 41 42   Go Down
Author Topic: Engine noise, terminal?  (Read 117690 times)
Re: Engine noise, terminal?
« Reply #540 on: 09 April 2010, 19:06:05 »
the suspense is killing me... What was it then?
Coolant bridge to BBC pipe had split. Small section replace now
Decking phone. BBC = hbv
Decking? rather phone and it's stupid spell checker
I also go mad with this word completing property ;D ;D
so still using ancient mobiles.. ;D
« Reply #541 on: 09 April 2010, 19:43:07 »
So... It's fixed again... Are we back on for the weekend? :-?
If so, one of you better bring a torque wrench (mine's a bit big!) and your preference of soldering equipment/tape/heat shrink etc :y
« Reply #542 on: 09 April 2010, 21:22:45 »
Err, see pm . Got smell of coolant again
« Reply #543 on: 09 April 2010, 21:31:13 »
Could just be lingering from earlier... I'd imagine it was everywhere ::)
« Reply #544 on: 09 April 2010, 22:02:58 »
Yes, mostly all over the A43 ::)
I need to see whats happened to the level once its cooled.
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #545 on: 09 April 2010, 22:06:53 »
Fingers crossed Jaime, your luck has surely got to change!
best wishes
Simon.
« Reply #546 on: 09 April 2010, 22:07:00 »
It will be very wet.....and very clean!
« Reply #547 on: 09 April 2010, 22:08:41 »
Done around 80 miles since the leak fixed. Would that have burnt off yet.
I should add, that 80 miles was most definately an unspirited drive
« Reply #548 on: 09 April 2010, 22:29:11 »
Judging by your description of a "Geyser" it will have soaked into the lining inside the bonnet ;)
« Reply #549 on: 09 April 2010, 23:55:50 »
So, this weekend, LPG and rev limiter fitted.   ::)
dad1uk
  • Birmingham
« Reply #550 on: 10 April 2010, 00:23:13 »
 :D :D ;D    - oops 'post count' :o!
best wishes
Simon.
« Reply #551 on: 10 April 2010, 00:43:35 »
ime the coolent smell will linger for some time, wonder if its worth a rinse off with a hose, esp on bits that get hot, tends to leave residue if it evaporates on hot parts, hence the burnt suger type smell....IME...?
« Reply #552 on: 10 April 2010, 01:58:53 »
mmm - should have engaged brain first.
« Reply #553 on: 10 April 2010, 09:22:51 »
FFS, I behaved, and did exactly what I thought I was told.  Was told to take it easy initially (so I didn't go above 3k rpm), then I was asked to give it a spirited drive.
Its this last bit where the misunderstanding was....
« Reply #554 on: 10 April 2010, 09:24:31 »
When I said a spirited drive I didn't mean a Malcolm Cambell esq land speed record attempt!
;D ;D ;D
« Last Edit: 10 April 2010, 09:25:56 by TheBoy »
Pages: 1 ... 30 31 32 33 34 35 36 [37] 38 39 40 41 42   Go Up
